'74 DT250 aftermarket fuel tanks/skidplates?
  • Pony Biy
  • Pony Biy's Avatar Topic Author
 A couple years ago, I found a thread on fitting a late 90's-early 2000's aluminum skidplate from a Honda XR, onto the 74-76 DT250-260-400. All it required was a little trimming at the rear for the drain plug on the DT.
 I had also seen a couple threads on aftermarket higher capacity plastic fuel tanks for the same year DT's, but I can't find anything on either subject now! I'm not sure if google changed search parameters or what, but if you have any info on either subject it'd be much appreciated!
04 Apr 2024 17:15 #1
Welcome!
04 Apr 2024 20:08 #2
Here is one of the threads on tanks...  you might contact DEET and see if he has one. yamaha-enduros.com/index.php/forums/1972...fla-fuel-tank#132426
Most people just use the stock skidplate...  I remember someone making one from Kydex...  I don't remember seeing anything about a Honda plate modified but someone else might.
Last edit: 05 Apr 2024 06:54 by MarkT.
04 Apr 2024 20:13 #3
Replied by nhsteve on topic '74 DT250 aftermarket fuel tanks/skidplates?
I stumbled on to an alloy one from an OSSA Pioneer that had already been extended by adding a section from another one. It actually fits quite well on the DT360A. I used the two top 6mm mounts on the frame near the engine mounts, and got two rear mount clips for an early DT1 for the rear. You wouldn't really need the extension.
I know there are OSSA guys around (I know one), maybe you could pick up something like that and make it work for you. There is also a seller on eBay selling an old one for a DT1 currently.
19 Apr 2024 06:33 #4
Replied by Bikes4Dan on topic '74 DT250 aftermarket fuel tanks/skidplates?
"...you might contact DEET and see if he has one."
I think I asked about this person's contact info in another place and it was deleted.
Can I get the contact info here?
28 May 2024 14:21 #5
Post number 6 of the link I gave was written by DEET and has his email at the bottom.  (It might sound silly, but I won't post someone's email...  they might want to go back and delete it someday and would not be able to if someone else posted it)
yamaha-enduros.com/index.php/forums/1972...fla-fuel-tank#132579
28 May 2024 15:13 #6
Thanks, found it and understood.
29 May 2024 13:50 #7
