76 DT400 modified air filter
- Visitor
Replied by on topic 76 DT400 modified air filter
Lots of posters on here seem not to be happy with the stock brakes? I can see that improved drum brakes, would certainly mean the stock chassis and forks, may well not be able to cope..............thanks for pointing that out!
23 Sep 2023 10:23
#31
- Kenduro
Replied by Kenduro on topic 76 DT400 modified air filter
Yes, arcing the brake shoes is(was) common place for auto drum brakes at a decent brake shop. Any shop that still has the old drum lathe can probably do that for you.
If brakes are aftermarket or poor fit, you might just have to advance the lever to lead the cam and cause it to ramp up quicker, but you'll have to have enough slack in the cable. If that is the case, they probably also need to be re-arced. If there's not enough slack to do this, the shoes are probably right sized. Also check how worn the actual lining inside the hub is, and not contaminated, and check for wear and size of both the cam and fixed pin on the backing plate.
Have someone familiar with old bikes ride it, you may be expecting too much if you've only ridden with disc brakes. You're not going to lift the rear tire unless you go to double leading shoes.
- Visitor
The main reason drum brakes in most cases dont work that great, is the lining material used. Upgraded linings, mean better brakes.
26 Sep 2023 00:28
#33
- MACE6772
Replied by MACE6772 on topic 76 DT400 modified air filter
All posts in this thread are not member MASE6772. I do not know who it is, but it does say visitor.
27 Jun 2025 14:20
#34
- Schu
Replied by Schu on topic 76 DT400 modified air filter
It views similar for me showing SCHU as posting but they are not me. It’s a quirky thing that just happens. No worries.
27 Jun 2025 14:23
#35
- Sneezles61
Replied by Sneezles61 on topic 76 DT400 modified air filter
I believe it was said, that when someone signs out/leaves, for some reason your name shows up in the moniker, only when YOU are looking at it.
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, pahiker
27 Jun 2025 15:28
#36
Replied by MarkT on topic 76 DT400 modified air filter
Exactly. If the original poster deletes their user account, their old posts stay but the software assigns the name of the person viewing to the post as a visitor and no avatar.
27 Jun 2025 22:09
#37
