DT175 gear change shaft boss in crankcases?
  • MarkT's Avatar Topic Author
I like that "fix"...  gives shifter a lot more support.  (Pretty sure you asked this exact question just a couple weeks ago? )
The following user(s) Liked this Post: DaveHunter
17 Jun 2023 13:03 #1
Replied by DaveHunter on topic DT175 gear change shaft boss in crankcases?
The XS650 had same problem, steel shaft wearing out the aluminum to an egg shape and oil leaks
17 Jun 2023 13:08 #2
There's so much info on this site it can be confusing...  gets even more confusing when multiple threads are started on the exact same topic.  Responses can get all mixed up and it really gets confusing.
Anyway, you pretty much have the tool. Simply find a milling bit to bore the case hole oversize and bush your adapter to fit the shank.
18 Jun 2023 08:17 #3
Replied by valencia blue on topic DT175 gear change shaft boss in crankcases?
Sounds like a good fix, any pictures?
24 Nov 2024 03:54 #4
