76 DT400 mistery plug
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 76 DT400 mistery plug
Hi guys, well it turned out to be bad ground, added a ground wire to the negative side of battery so all is well there. I have everything working correctly except right rear turn signal and tail light. Rear turn signal wont come on at all and tail light blinks with right turn signal on. I tried grounding right rear turn signal with no luck. I know I saw something here about tail light blinking with turn signal on but can't remember where or what was the cause. Anyway I hope all here in the States (colonies to you guys across the pond), are having a good Memorial day...
29 May 2023 07:33 #31
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Update: I figured out the taillight issue though I need to check the bulb since the light isn't actually coming on but brake light is working. I remembered that I didn't have the front brake lever on which was causing the actuator pin in there to be out (if that make sense), so I put the brake lever on and connected the front brake. Hope all that is clearer than mud...
29 May 2023 15:58 #32
Replied by RT325 on topic 76 DT400 mistery plug
The old "faulty earth trick". We've all been caught out by that at some stage. Great ya found it.
29 May 2023 16:16 #33
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks Morley, now if I can just figure out why the taillight doesn't come on but headlight does, hoping it's just the bulb, and of course figure out why the darn right rear signal isn't working. If I can get those two sorted my electrical system will be good to go.
29 May 2023 16:19 #34
Is your tail light DC off the battery or AC like our models. Of course brake light is DC. Had some weird things with cheap bulbs at times with DC brake filament leaning over & touching the AC tail filament. Unlikely--but!!.
Last edit: 29 May 2023 16:40 by RT325.
29 May 2023 16:39 #35
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Good morning Morley (well it's morning here), You're asking the wrong guy if the tail light is AC, I'm lucky I've gotten this far with the electrical. I'm going to check the bulb today and hope that's the issue. The replacement tail light is a cheap e-bay part but it's the only one I could find, the original had some rust on the chrome so I wanted to replace it.
30 May 2023 02:01 #36
Yes i think the US ones might have DC tail lights. [not sure what year that started though? if not always the case]. But if that 'is' the case & DC i'd expect it to be powered by a light brown. If run off the mag with the headlight i'd think it'd be blue. Happy to be corrected by someone [everyone] but my long term memory is better than short term [sorry what was the question again lol].
The following user(s) Liked this Post: AirborneSilva, Sneezles61
Last edit: 30 May 2023 02:48 by RT325.
30 May 2023 02:43 #37
  • AirborneSilva
  • Platinum Member
  • Platinum Member
I have the Vape 12v, both headlight and tail light run off the battery, I think lol at least the headlight comes on with just the key and if I remember correctly (it's been a few months since I tore this bike down), the tail light also comes on with just the key.
30 May 2023 02:47 #38
Replied by Gr8uncleal on topic 76 DT400 mistery plug
I think DC = off battery and AC when engine running.
Still probably a blue wire for DC, but a different circuit from the blues for the clocks lighting! This confused me for a while when I was testing some CT looms for continuity.
30 May 2023 02:50 #39
Ok haha, i'm well off the case then with this modern vape stuff. I'll get back in the corner haha. Hope ya sort it out.
30 May 2023 02:51 #40
