Rack and exhaust fitting on a 1975 DT175
- jeffjeffjeff
Rack and exhaust fitting on a 1975 DT175 was created by jeffjeffjeff
I can't figure out how the exhaust bracket and rack are supposed to fit for this model and I can't find diagrams on Partzilla.
1. I can't see any way the bracket would fit without cutting down the mounting stud on the rack to make room. Photo below.
2. It appears that this bracket requires some kind of bushing - Yet Partzilla doesn't indicate one. Photo below.
Does anyone know the proper way this is supposed to fit together with pictures hopefully?
Thanks.
photos.app.goo.gl/4QKjg1LMbNLvUZsDA
photos.app.goo.gl/XYR9LkRSiS16MosB7
Thanks.
27 Jan 2023 16:36
- AirborneSilva
Replied by AirborneSilva on topic Rack and exhaust fitting on a 1975 DT175
Have you thought about removing the spacer that's between rack and fender? Looks like the exhaust bracket has it's own spacer.
28 Jan 2023 03:26
Replied by MarkT on topic Rack and exhaust fitting on a 1975 DT175
I can't tell enough from the zoomed in picture of rack and no view of the silencer....
I don't think I've ever had a correct rack for a 74-75 DT175
28 Jan 2023 03:39
- JayB
Replied by JayB on topic Rack and exhaust fitting on a 1975 DT175
Mine looking forward from the back left to right is: Bolt head - luggage rack - exhaust bracket - thick rubber bushing - frame tab - fender rubber bushing - rear fender.
I took a picture but I guess I still can't post it.
Jay
Jay
28 Jan 2023 13:55
- MACE6772
Replied by MACE6772 on topic Rack and exhaust fitting on a 1975 DT175
Checked my 75. Same as Jayb's above.
28 Jan 2023 14:01
- JayB
Jeff,
In answer to your PM question, see pictures in post number 12 here:
yamaha-enduros.com/index.php/forums/74-7...brain?start=10#63983
In post number 12 you can see the uneven hollow posts on the DT175 rack.
28 Jan 2023 15:57
- jeffjeffjeff
Replied by jeffjeffjeff on topic Rack and exhaust fitting on a 1975 DT175
Thanks everyone for the help. Got it. It's just the rack and then the bracket that just bolts directly against the frame with no bushing. Just kind of a weird design.
28 Jan 2023 22:08
