AUTOLUBE DETAILS
- automan
AUTOLUBE DETAILS was created by automan
Hi All!
Do any one of you mugs know what the oil pump outlet check valve pressure is???
cliff
cliff
25 Jan 2023 09:04
- asco
Replied by asco on topic AUTOLUBE DETAILS
MUG-LIGHT
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
25 Jan 2023 14:42
- msavitt
Replied by msavitt on topic AUTOLUBE DETAILS
Pump is positive displacement gizmo with output that varies based on speed and throttle position. Flow typically specified in terms of a few (e.g. 5) cc's at 200 strokes with throttle wide open, so not enough flow or restriction to generate any measurable pressure, which is probably why every spec that I have seen lists cc's of output and not pressure
25 Jan 2023 16:57
- Swoop56
Replied by Swoop56 on topic AUTOLUBE DETAILS
Kawasaki and Suzuki install their check valves at the end of the oil line , so the blow off pressure can be checked .
Yamaha have their check valve at the pump outlet , so it can't be tested the same way .
25 Jan 2023 20:14
- automan
Replied by automan on topic AUTOLUBE DETAILS
Thanx guys. I am testing one right now and get about 1 psi. I think this is fine to prevent hydraulic lock-up.
Still have to test G force influence on the ball/spring operation.
If it seals and stays sealing, all good I would think at this point.
BTW the pump is not positive displacement at low flows and RPM's due to leakage.
Frosty
Frosty
