12 volt conversion kits
  • chucklenutz
  • chucklenutz's Avatar Topic Author
12 volt conversion kits was created by chucklenutz
Hi all,  I have a 1976 DT 400 C . Looking to do a 12 volt upgrade because my CDI module is out of spec. Wondering which kit I should go with? Would like to delete battery, I've looked at the Vape and Rex's. Any experiences or suggestions Please!
23 Oct 2022 11:13 #1
Replied by AirborneSilva on topic 12 volt conversion kits
I installed the Vape 12v conversion kit on my 76 DT400, love it. was not difficult to install, the bike starts easy and runs great (or did until the big end rod bearing went out), the price is right and shipping from Europe was fast and cheap. I've heard some people had issues with Rex's so that's why I went with Vape.
The following user(s) Liked this Post: chucklenutz
23 Oct 2022 12:54 #2
Replied by Andy_C on topic 12 volt conversion kits
I fitted a Rex's to my 400C.
No problems, easy to fit, starts / runs perfectly.
They do a version that does not need the battery, but I went for the battery option.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
24 Oct 2022 08:06 #3
  • chucklenutz
Replied by chucklenutz on topic 12 volt conversion kits
What problems are they having with the Rex's kit?
Last edit: 24 Oct 2022 13:41 by chucklenutz. Reason: /
24 Oct 2022 13:40 #4
You can do a search but what I've seen is that some of the connections are made for European bikes and are not quite the same as US models, also support is lacking from what I've read. I sent an e-mail out to Vape, they returned it the next day...
24 Oct 2022 13:47 #5
There was one wire in my Rexs conversion that was in the wrong position in the connector, solution was simple, move it to the correct position.
I called Rex's about this and the guy I spoke to was very helpful, but then again I am based in the UK.
The kit comes with comprehensive fitting instructions - easy to follow, easy to do.
24 Oct 2022 14:58 #6
Replied by Jammyyammy on topic 12 volt conversion kits
It is my understanding that the Rex conversation fits UK model DT400s (B and C) without any issues. If the bike is a USA model, there needs to be a link inserted in one of the connectors, otherwise the battery doesn’t get charged. Simple job. Search the forum for details of the mod required.
25 Oct 2022 14:12 #7
Replied by MarkT on topic 12 volt conversion kits
Do a forum search to research issues.  The wiring jumper is needed on B models and is not really an issue.
25 Oct 2022 14:42 #8
Mine is a 400 C USA Spec, no need to jump anything just re locate one of the wires in the connector in the Rex's loom. Think it was the green wire.
Charges just fine.
26 Oct 2022 10:42 #9
  • chucklenutz
I'm going to do battery delete, wonder if I will need to move wire?
26 Oct 2022 20:48 #10
