Clutch cover removal
  • kwzl1
  • kwzl1's Avatar Topic Author
Clutch cover removal was created by kwzl1
On to my next project on my DT175-replacing a slipping clutch.
Tried to remove the screws in the right-side case/clutch cover and they won't budge. Not even with a small hand-held impact driver.
Any suggestions on how to remove them without stripping the screw heads or damaging something?
Thanks!
18 Aug 2022 17:28 #1
Replied by RT325 on topic Clutch cover removal
No sensible suggestions as unlikely some noddy has loctited them in, well hope not. So long as you're holding the impact driver to the left while hitting it the screws just have to turn--in theory. Great thing theory!!. Best of luck.
19 Aug 2022 03:31 #2
Replied by Gr8uncleal on topic Clutch cover removal
Just check that you are using JIS bits in the impact driver, not Phillips.
19 Aug 2022 03:38 #3
Replied by MarkT on topic Clutch cover removal
#3 bit
19 Aug 2022 06:32 #4
Replied by Schu on topic Clutch cover removal
When you refer to a small handheld impact driver, are you referring to the type you smack with a hammer, or are you referring to a handheld power tool?
You want the hammer smacker.
19 Aug 2022 09:19 #5
