What are the options
Replied by RT325 on topic What are the options
Sounds like maybe you're trying to fit it onto the plug with the screw top still on the plug. Remove it then the cap will click down the plug top thread. Just a thought though, if you plug top doesn't unscrew then you have the wrong sort of spark plug.
28 Jul 2022 04:48 #21
Replied by Ht1kid on topic What are the options
Did you unscrew the spark plug cap?
28 Jul 2022 04:54 #22
  • Turbotim
  • Turbotim's Avatar Topic Author
Replied by Turbotim on topic What are the options
I have a lbo5f plug cap doesn't fit new
A lzo5fm red ngk plug cap doesn't fit new
Straight kvas plug cap this fits but its broken
B8es plug..
28 Jul 2022 05:20 #23
  • Turbotim
Spark plug....
28 Jul 2022 05:26 #24
Replied by Doctor K on topic What are the options
A small chisel, liquid wrench, and a careful tapping on upper left side (turning the screw counter-clockwise) should break it loose. Obviously find a new screw, and that should do it. I am a bit concerned about all the particles I see there - be sure your rotor is not worn, as it is also the points cam. Dr K
28 Jul 2022 07:33 #25
Replied by MarkT on topic What are the options
LB05F is designed to be used with the terminal unthreaded from the spark plug...  fits over threaded stud.
On some plugs the terminal is not removable but if those are your pictures it looks like yours is.
28 Jul 2022 08:03 #26
  • Turbotim
Yes I see...cheers guys...school boy error on my part.
Just on most things I've worked on i always
Left the terminal on..  anyway fits a treat with terminal off
cheers guys...
28 Jul 2022 09:15 #27
