DT 400 B shunting update.
- Pedalcrazy
Replied by Pedalcrazy on topic DT 400 B shunting update.
Left side idle adjust too so looks correct.
20 Nov 2022 19:01
#21
Replied by MarkT on topic DT 400 B shunting update.
Does anyone know the OD of the slide? I have a box of short and tall slides and might have a tall one in 2.5
20 Nov 2022 19:09
#22
- AirborneSilva
Replied by AirborneSilva on topic DT 400 B shunting update.
Thank you Pedalcrazy...
Mark, just measure mine with my cheap harborfreight caliper, measured 35.45 mm. If you have one I'd sure be interested in it!
21 Nov 2022 02:53
#23
- Jammyyammy
Replied by Jammyyammy on topic DT 400 B shunting update.
You beat me to it. I get 35.41mm
21 Nov 2022 04:35
#24
2.5 slide I found is ~35.4 mm diameter by 54 mm tall... anodized aluminum... has the two threaded holes down inside to accept cable holder piece that some carbs use... so not sure it will work on 75-76 DT400.
25 Nov 2022 19:03
#25
- AirborneSilva
Thanks Mark, if you're not sure I'd hate to chase something that may or may not work. I appreciate you looking!
26 Nov 2022 02:04
#26
I don't know for sure how cable attached on 75-76.
26 Nov 2022 07:36
#27
- AirborneSilva
Good morning Mark, the second and third picture in this ebay add shows how cable attaches to the slide.
Throttle slide
Throttle slide
26 Nov 2022 07:45
#28
That's what I thought... the keyhole slot. This slide has the screw-in bracket that holds the cable.
I'm sure it could be made to work, I just don't know if cable length is significantly different. Might need to shorten inner throttle cable to slide slightly.
26 Nov 2022 08:02
#29
- AirborneSilva
Thanks Mark!
26 Nov 2022 08:03
#30
