DT400B Twin Shock - neutral light query
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
DT400B Twin Shock - neutral light query was created by Jammyyammy
Hi all,
My (American import) DT400 twin shock doesn’t have a neutral light. Am I dreaming, or do some DT400 twin shocks have a neutral light? If so, I presume it was the later ones that had a neutral light or was it the European ones had a neutral light?
I don’t suppose a retrofit is possible to mine?
Thanks..
Last edit: 11 May 2022 12:28 by Jammyyammy.
11 May 2022 12:27 #1
Replied by Bigdog302 on topic DT400B Twin Shock - neutral light query
No they don't have a neutral light. there is not even a neutral light switch on the engine case.
Dave
Jesus is Lord!
11 May 2022 15:50 #2
Replied by RT325 on topic DT400B Twin Shock - neutral light query
Selector drum is at the base of the motor not like the smaller motors with it at the top & easy to design in. They probably thought if we put one under the motor its going to give grief, leak, get knocked off.
11 May 2022 15:59 #3
Replied by Pedalcrazy on topic DT400B Twin Shock - neutral light query
When Yamaha started the monoshock version of the DT400 in 77 it got a neutral light and oil tank low level light.
11 May 2022 16:38 #4
Umm--ok. The sorts my theory haha. Number 39 below.
Last edit: 12 May 2022 02:30 by RT325.
12 May 2022 02:28 #5
12 May 2022 02:29 #6
Here it shows the raised button to earth the neutral light.
12 May 2022 02:39 #7
  • Jammyyammy
Replied by Jammyyammy on topic DT400B Twin Shock - neutral light query
Thanks for all your responses…
12 May 2022 03:33 #8
