correct source coil resistance
- Sneezles61
Replied by Sneezles61 on topic correct source coil resistance
I'll suspect the condenser.
Sneezles61
Sneezles61
22 Mar 2022 19:23
#21
- Jbeebe
Replied by Jbeebe on topic correct source coil resistance
I wish! I already replaced the condenser. thanks though, keep the suggestions coming!
23 Mar 2022 03:41
#22
- Jbeebe
yes, once I installed new points/condenser I re-timed the bike using a dial indicator and ensured that the points are opening/closing as they should.
23 Mar 2022 03:43
#23
- Jbeebe
unfortunately I don't have the original ignition coil. so i'm left with just aftermarket options
23 Mar 2022 03:43
#24
Replied by MarkT on topic correct source coil resistance
Have you checked/set your plug gap to 0.020 to 0.024"?
It's starting to sound like the scenario described where the source coil is acting up... I've never had it happen to me but another member documented it pretty well. I think he posted here earlier.
23 Mar 2022 07:19
#25
- alnarv
Replied by alnarv on topic correct source coil resistance
After points/condenser replace and re-time and still getting intermittent spark, the problem could still be either ignition coil or source coil. Others on this site have had good experience with the Emgo coils, so points to source coil, but not certain. You could try another ignition coil, but to be sure whether it is either, you should measure the peak voltage coming out of the magneto. The meter you show in your 1st picture only updates twice/ second (500ms). That is not fast enough to catch the spike from the mag. Perhaps you could borrow a meter (or maybe rent?) with a peak read function. You need a 1ms update to see the correct value from the magneto.
23 Mar 2022 07:33
#26
Also, clean NEW points by pulling strips of white tuft-free card stock (white uncoated business card) through them until it comes out clean.
I've had brand new points not work... sitting in storage an invisible layer of corrosion can form on contacts creating intermittent/no spark
Replied by RT325 on topic correct source coil resistance
Badly crimped joints or pad fitting connector blocks can cause problems too.
23 Mar 2022 13:52
#28
- Sneezles61
Old twin cylinder snow sleds... When a condenser starts to go... One cylinder, the bad one, won't run while it idles but the sled will run... Once you get some RPM's up, the bad cylinder starts working... I've found I need to take the condenser right out of the sled, and test it while sitting on a piece of wood... I doesn't take much to complete the circuit/grounding the condenser attached to metal... Very frustrating..
Sneezles61
Sneezles61
23 Mar 2022 14:11
#29
Replied by Ht1kid on topic correct source coil resistance
Are points and condenser aftermarket or Yamaha?
23 Mar 2022 16:00
#30
