74 DT 175 r/h crank end nut
Replied by Sneezles61 on topic 74 DT 175 r/h crank end nut
What happens in the "shed"... stays in the shed... No kiss and telling!!
Sneezles61
17 Mar 2022 06:21 #11
Replied by alnarv on topic 74 DT 175 r/h crank end nut
I've always used an impact wrench to remove, but never to install. Wadded up rag between gears on crank and basket then torque wrench to tighten.
alnarv
17 Mar 2022 06:43 #12
Replied by Tom P on topic 74 DT 175 r/h crank end nut
I've been reading so many threads of people having problems with wedges and different methods. I'm beginning to think I'm just going to hold my clutch basket with a strap wrench and hit both the primary nut and the clutch nut with my cordless impact gun, with a little blue Permatex on the thread. Not even worriy about torque specs. I've read people using a strap wrench while using a torque wrench, and it ends up breaking the strap wrench.
I found a picture of a Yamaha manual where they say to use a little aluminum wedge, but I'm just not a fan of sticking metal into gears, even if it's a soft metal.
Last edit: 17 Mar 2022 09:53 by Tom P.
17 Mar 2022 09:52 #13
I wonder how many people miss that there's a tiny little O ring in a groove on the right hand drive shaft, that goes under the spacer? I've seen that there's a Yamaha part number for this, but I think I'll just go to an auto parts store and try to match it up.
17 Mar 2022 10:38 #14
Replied by Schu on topic 74 DT 175 r/h crank end nut
That o-ring is in my tiny $150 bag……
17 Mar 2022 15:06 #15
I wonder what that O-ring is made of? Is it silicone, or vitron? From what I'm reading, you can't use neoprene or nitrile. I guess I'll have to order one that's OEM, because I don't want to take this thing apart again by putting the wrong o-ring in there and having it fail under the heat and other conditions.
17 Mar 2022 18:21 #16
I scrounged around in my garage, and I think I found a perfect tool to press the seals in with... a 1 1/2" OD sink drain tailpiece. The seal fits perfectly on it, with enough flange on the outside that it will stop the seal from pushing in too far.
Last edit: 18 Mar 2022 08:47 by Tom P.
18 Mar 2022 08:45 #17
Replied by RT325 on topic 74 DT 175 r/h crank end nut
Great idea
18 Mar 2022 18:07 #18
