74 DT 360
  • Chitter
  • Chitter's Avatar Topic Author
74 DT 360 was created by Chitter
i know most on here only restore, but im looking to Vintage race this bike and would like comments, on how to eliminate oil pump tank, also want  plastic rear fender, and metal footpegs, side and front # plates.   anything anyone can add to make this a Vintage hare scramble bike
11 Feb 2022 11:43 #1
Replied by adguy2112 on topic 74 DT 360
My first thought is how can I talk you out of it? What Vintage MX bike would be able to take it's place? I think they use a lot of ITs in these races, no?
Sorry, you still came to the right place. I so miss my DT360 and the thought of another one of the remaining being stripped down makes me want one all the more. I still have the tank from it. Crashed into the side of a car in 1981.
11 Feb 2022 12:48 #2
Replied by Schu on topic 74 DT 360
Here's mine. I go against the grain on a lot of things. Mainly because I try and keep my cost to a minimum but still have fun with the old vintage Yamaha's.
The following user(s) Liked this Post: RT325, JayB, adguy2112, Mike P, Chitter
Last edit: 11 Feb 2022 13:33 by Schu.
11 Feb 2022 13:26 #3
Replied by RT325 on topic 74 DT 360
Pump will survive if you cap it where the tank line enters. Then remove any shims under the plate that moves up & down [in & out then]. Remove cable & fit a stronger carb slide spring. & off ya go. Could remove the pump though if you wanted to pull the clutch cover off to blank things off. Reading again i see you say oil pump tank, or do you mean pump & tank?. Good bike the old 360A but not much ground clearance unless you jack it up a bit. I have an RT2 style vmx'er with more clearance on that model. 360A is a stronger motor & totally re-designed for "74. Look forward to pics sometime. What country are you in?. Cheers & welcome from NZ.
Last edit: 11 Feb 2022 14:06 by RT325.
11 Feb 2022 14:03 #4
  • Chitter
Replied by Chitter on topic 74 DT 360
yes that’s the look i’m going for, won’t be cutting or destroying anything, it could all go back on later if someone chooses. i just will only be racing it at Mid Ohio national hare scrambles, might motocross for fun. yes an old Yamaha IT would be great , i used to race one back in the day. but my dads last dirt bike was this same model , plus i kinda wanted in the class that is basically 74 and older.   curious what tear fender did you use .
11 Feb 2022 14:22 #5
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=233209735865&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by JayB on topic 74 DT 360
I hope to see you at Mid Ohio!
11 Feb 2022 16:36 #7
Not sure if these pegs will fit, but it looks like what you wanted.
11 Feb 2022 18:36 #8
  • Chitter
did you completely remove the oil tank or just disconnect it, nice looking bike!
14 Feb 2022 12:54 #9
I completely removed the oil tank and the oil pump. I made a plate to cap off the oil pump mounting using a new gasket on the homemade cap. I simply made a cap out of 1/8 aluminum and made it the same shape as the gasket. Drilled two holes and done. It looks just like the block off plates you can buy on eBay for around $20 dollars, except it was free!
14 Feb 2022 14:03 #10
