DT400b oil tank window removal
  • GaryDean
  • GaryDean's Avatar Topic Author
DT400b oil tank window removal was created by GaryDean
Hi Guys
I decided to repaint my oil tank but I did not want to remove the window for fear of constant oil contamination. So I painted the tank today and left the window in, I have a replacement window to fit, but dont want to gun ho it and ruin the paint job, so can you push these into the tank for removal or drill them and pull them?
thoughts appreciated from anyone that has removed 1
26 Jan 2022 08:18 #1
  • GaryDean
Replied by GaryDean on topic DT400b oil tank window removal
26 Jan 2022 08:20 #2
Replied by adguy2112 on topic DT400b oil tank window removal
Here is a post thread on the subject that may help you…
www.yamaha-enduros.com/index.php/forums/...s-replacement#133668
26 Jan 2022 08:31 #3
  • GaryDean
hi thanks for that, but it does not cover getting the thing out, only putting a new one in. I suspect I need to warm up and try pushing it in without denting the tank?
26 Jan 2022 08:37 #4
Replied by Gr8uncleal on topic DT400b oil tank window removal
I've not done it myself, but I've read many times that folks have drilled a small hole, inserted a self tapping screw and pulled it out.
If the thread that adguy attached doesn't mention this, don't use too much force when pushing in the new one, otherwise it will end up in the tank itself!
26 Jan 2022 09:41 #5
Replied by Pete-RT1 on topic DT400b oil tank window removal
Not sure about you tank, but on the CT1 I push the original through then remove it from the filler hole.
Installing the replacement I use a plywood disc about 2 inches diameter and press that against the new window.
Using the disc will stop you pushing it in too far, which is what I did on my first attempt, lesson learnt
A little oil on the rubber will help too.
Good luck.
Yamaha CT3 (in bits)
26 Jan 2022 11:50 #6
Replied by Schu on topic DT400b oil tank window removal
I drilled mine and pulled it with a large wood screw.
And then I found a surprise inside the oil tank.
The following user(s) Liked this Post: 1971DT250, JayB, Sneezles61
26 Jan 2022 14:11 #7
  • GaryDean
thanks for the replies guys, I will go with the push first and fish out the tank through the filler, if this seems to not move I will go with the drill and pull, I think the latter may get the tank damaged when I drop it on the floor trying to pull it out LOL
then follow the disk trick when re installing
27 Jan 2022 07:48 #8
Replied by MarkT on topic DT400b oil tank window removal
Some tanks are easy to dent pushing on window.
27 Jan 2022 15:46 #9
Replied by 1971DT250 on topic DT400b oil tank window removal
One of mine has one inside the tank. I left it in there. Don't want to risk any damage trying to get it out.
27 Jan 2022 16:11 #10
