YAMAHA DT400B CARB PROBLEMS
- GaryDean
Replied by GaryDean on topic YAMAHA DT400B CARB PROBLEMS
took the bike out today and as above I think the bucking problem now solved. It took me 8 kicks to start some harf harted, initial run was rough at low speeds prob due to now a rich lower end, tickover to 1/4 throttle rough after that ok, i stopped for 2 hrs then tried to start in the past i found i needed choke (before bottom adjustement) i employed the same regime and 10 kicks later 1 with a kick back that I think has twisted my ancle it started all blubbery. I still need to get the top dead knack sorted out, but was thinking now I have richened the bottom end do I re need choke to start?
19 Nov 2021 09:36
#21
- Pedalcrazy
Replied by Pedalcrazy on topic YAMAHA DT400B CARB PROBLEMS
Garydean...glad you are happier with the lower end richer. Mine also is quite blubbery down low until warmed up then runs good with minimal bucking. I'd still try lowering your idle...1500 is still higher than needed and lower will help reduce bucking on closed throttle coming to a stop or slowing down. Only thing is mine is not hard to start cold or warm. Three modest kicks at worst. Maybe try as manual says...start cold with choke on and throttle closed. Start warm with no choke and crack the throttle. Of course it is subjective on just how warm or cold it is. If pretty warm just crack the throttle when kicking. If doesn't start in two of three then choke on. Good luck!
19 Nov 2021 14:56
#22
- adguy2112
Replied by adguy2112 on topic YAMAHA DT400B CARB PROBLEMS
Is it possible the two issues are unrelated? Seems the hard starting could be due to something impeding the flow of fuel in the starting jet. Regardless of how these bikes run under throttle, I've begun running thin wire through all the passages possible repeatedly and I almost always find some small impediment when I have hard starting issues. Just a thought. A first kick start is certainly preferable.
19 Nov 2021 15:23
#23
- GaryDean
Hi Guys, thanks for the replies, my ankle is quite sore today so its going to be a few days before I have another go with it, but I will adjust the tick over and see if I can get it down without cutting out, as at tick over the engine is popping and rough, taco needle is not smooth at tick over
what figure do you use for your tick over?
Good point on the carb, I have bought a carb cleaning wire and brush kit for poking through jets etc, so while healing I will pop the carb again.
When I fitted the Rex speedshop ignition 6 weeks ago it would start on the first or second kick cold so maybe there is a restriction with dirt happening now preventing the an easy start.
subsiquent starts I just feel each kick is kicking back or trying to kick back till eventually its caught right and starts. I still dont think I have the tecnique yet for starting.
Ive checked the de compressor and that seems to be operating correctly but still a massive amount of compression there when starting. other than that the bike pulls like a train on steroids
20 Nov 2021 02:47
#24
- hatrick1960
Replied by hatrick1960 on topic YAMAHA DT400B CARB PROBLEMS
After reading all of these posts I decided to purchase a larger Pilot (55) and a 2.5 Throttle slide.The slide arrived today and although it is a genuine Mikuni the overall length is some 10mm shorter than my stock.Have I ordered the wrong one?Please see attached pictures
26 Apr 2022 06:49
#25
Replied by MarkT on topic YAMAHA DT400B CARB PROBLEMS
Yes, and you probably won't be able to get one from Mikuni.
Yamaha specified a tall cap carb which needs the tall slide. Short slide can create a dangerous stuck throttle condition with tall cap.
You can either swap to short cap (might need to mess with cable) or get a tall slide.
26 Apr 2022 08:29
#26
- Jammyyammy
Replied by Jammyyammy on topic YAMAHA DT400B CARB PROBLEMS
Hi, this is all good information. I’ve got similar issues with my DT400B, so am keeping a close eye on developments. Thanks for posting…
26 Apr 2022 12:12
#27
Replied by RT325 on topic YAMAHA DT400B CARB PROBLEMS
Ignore me if i'm way behind.!! If it's kicking back with a Rex's non-keyed flywheel, could it have moved foward firing sooner [advanced].
26 Apr 2022 16:52
#28
- Swoop56
Replied by Swoop56 on topic YAMAHA DT400B CARB PROBLEMS
Hatrick ,
Later model DT 400 's use a 2.5 slide pn 1M2-14112-25
Check it out , i'd expect it to be the same length as your early 400 slide .
26 Apr 2022 22:12
#29
- Jammyyammy
Hi,
Is the UFO slide based on a 2.5 or 3.0? Or is that irrelevant for a UFO slide?
27 Apr 2022 00:28
#30
