DT 175B advance
- wkosko
DT 175B advance was created by wkosko
Well my 75 175 had run fantastic until the c clip broke and took out the source coil. I managed to repair the advance but need a spring since it was mangled in the mayhem. May try and go to the hardware store to try and get close to original. Source coil is not looking good and needs rewound or replaced. Does anyone have a spring, advance, flywheel and or spare coil for sale? Thank you in advance
15 Aug 2021 17:13
Replied by RT325 on topic DT 175B advance
Could, if you wanted, just lock it on advance & tig the cam in a couple or 3 spots & no more problem. They may have quite a high geared kick ratio & not a very long kick lever so a good kick required. But think that system fell out of favor shortly after, although i did like it on the early 360.
15 Aug 2021 18:15
Looks like the second lighting coil stuffed rather than source, so might be able to carry on--if i'm right.
15 Aug 2021 18:18
- wkosko
Replied by wkosko on topic DT 175B advance
Thanks for the tip. I can tig or lock it.
16 Aug 2021 04:04
- wkosko
Great, thank for the reply and clarification. Wasn’t sure but now that I think about it the cam on the flywheel got out of time when the advance came apart. May send it out for rewind or track one down. There is a vintage jap swap meet show in York Springs this weekend 8/20-8/22.
16 Aug 2021 04:09
