Race Tech Emulators for 74 DT250A
- LWC82PE
Race Tech Emulators for 74 DT250A was created by LWC82PE
Can anyone tell me which are the correct Emulators for this model?
RT's site only lists up to 73 DT250 then skips 74/75/76 and starts again at 77.
Are adapters needed? If so are they included in the right kit or do they have to be bought separate.
05 Aug 2021 01:42
- Bigdog302
Replied by Bigdog302 on topic Race Tech Emulators for 74 DT250A
Race tech did not list the 1974 DT250 but they do list the 1974 DT360 and the 360 I believe has the same forks as the 250 in this case.
racetech.com/ProductSearch/12/Yamaha/DT360/1974
they also list the 1975-76 DT400 and I bet that same kit would work on the 1975-76 DT250. the forks on those 2 models are also very similar.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
- LWC82PE
Replied by LWC82PE on topic Race Tech Emulators for 74 DT250A
Ok but you dont know for sure if 74 DT250 forks are same as DT360 forks?
I will see if i can compare part numbers for damper rods and the tubes.
05 Aug 2021 15:40
- JGersh
Replied by JGersh on topic Race Tech Emulators for 74 DT250A
Give Race Tech a call… They are always very helpful
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
The following user(s) Liked this Post: MarkT, Bigdog302
05 Aug 2021 16:07
- LWC82PE
I dont live in USA so theres time zone issues.
Anyway i was able to find out these forks use same damper rods and inner tubes
Part # = 291-23170-60-00
Part Description = CYLINDER COMPLETE
Model Count = 10
DT1E 1971 250 DT1 Dual Purpose
DT1MX 1971 250 DT1MX Dual Purpose
DT2 1973 250 DT2 Dual Purpose
DT250A 1974 250 DT250 Dual Purpose
DT3 1973 250 DT3 Dual Purpose
DT360A 1974 360 DT360 Dual Purpose
RT1B 1971 360 RT1 Off-Road
RT1MX 1971 360 RT1MX Off-Road
RT2 1973 360 RT2 Off-Road
RT3 1973 360 RT3 Off-Road
Part # = 291-23124-60-00
Part Description = TUBE,INNER
Model Count = 14
DT250B 1975 250 DT250 Dual Purpose
DT250C 1976 250 DT250 Dual Purpose
DT400B 1975 400 DT400 Dual Purpose
DT400C 1976 400 DT400 Dual Purpose
so i looked at what 74 DT360 uses on RT's site and it says FEGV 3004 so this would work for the 250 too.
Model Count = 10
Model Count = 14
