1975 DT175 Stumbles above 3500rpm
- kwzl1
1975 DT175 Stumbles above 3500rpm was created by kwzl1
Hi,
I bought a 1975 DT175 eight months ago, not running. I have been working on it ever since and have everything working finally. However, one problem has me stumped. The bike starts and idles fine. But when I try to accelerate, it starts to sputter about 3500 rpm, and won't rev beyond 4500rpm.
I have checked all components in the ignition system. Stator ignition coil tests good, as does the main coil. I have replaced the spark plug 3 times, the plug cap, the condenser 3 times, the points, and adjusted the timing both to spec and on either side of spec. Nothing makes any difference. I have also rebuilt the carb twice (once myself, and once again by a local shop in case I missed something). I have changed the main jet. The plug color looks fine. I also replaced the reeds as they were original, and not closing.
In desperation, I took the bike in to the shop. They changed the condenser, and after two weeks told me it wouldn't start and had no spark and that I needed to come get it. (Not sure what they did, but the entire electrical system was dead. I took everything apart, tested, and reassembled. Now it all works again, but I still have the stumble.)
I was hoping to enjoy this little bike this summer, but I am out of ideas of what else to check/adjust. Anyone have any ideas?
I have attached a video and the audio shows how it sounds. (Ignore the upside down video portion, as I was holding my cell phone with one hand.)
Thanks, I appreciate any help.
This message has an attachment file.
Replied by RT325 on topic 1975 DT175 Stumbles above 3500rpm
No video this end or am i just not seeing the link. Anyway--first thought is exhaust restriction in the tail section. Needs a burn out especially in the spark arrestor area deeper in the end.
But hold that thought above. Looking at parts pic i see it still has Oring3 which seals into the bowl to make sure the mainjet does its job otherwise it leaks past & drowns it up in the revs.
The following user(s) Liked this Post: Bigdog302, darinm, Pedalcrazy
- Bigdog302
Replied by Bigdog302 on topic 1975 DT175 Stumbles above 3500rpm
Sounds like a plugged up exhaust to me. time to burn out the pipe. burn out the pipe and burn out and clean the baffle.
I don't see the video or a link to it too.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
- kwzl1
Replied by kwzl1 on topic 1975 DT175 Stumbles above 3500rpm
Thanks for the response. I did burn out the silencer (back half of the exhaust system-baffle?), but didn't get a lot of smoke out of it. didn't do the main exhaust pipe.
Video was there when I posted, but maybe wrong file type. Tried again with a zip file.
24 Jul 2021 21:43
- kwzl1
did you mean oring 3? I replaced it as the old one was hard, but didn't help.
I tried adding the video again.
Thanks for your reponse.
24 Jul 2021 21:46
Replied by Gr8uncleal on topic 1975 DT175 Stumbles above 3500rpm
Air filter original, clean and not over oiled (if oil type)?
Sorry yep Oring3 now i have my glasses on haha. You're onto though so all good. No video though. Hanging out for it to hear what its doing.. Think ya have to put it somewhere like youtube & link it over. I'm not good at that stuff. Might have to use Reply in place of quick reply.
25 Jul 2021 02:05
- asco
Replied by asco on topic 1975 DT175 Stumbles above 3500rpm
You said that you changed the main jet but you didn’t tell us which way you went from what to what and what is stock?
Sometimes’ it’s difficult to get these bikes up to red-line’ but it has been done.
Any restriction from the air cleaner to the exhaust tip can work against you.
asco
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
25 Jul 2021 08:53
- Pete-RT1
Replied by Pete-RT1 on topic 1975 DT175 Stumbles above 3500rpm
To add a video, upload it to Youtube and then paste the link.
Yamaha CT3 (in bits)
25 Jul 2021 09:36
- kwzl1
Yes, air filter is good.
25 Jul 2021 10:30
