What size exhaust bolt/stud on 1975 Yamaha DT125 Enduro
  • Patroll330
  • Patroll330's Avatar Topic Author
Took my exhaust off for repairs and one stud broke off in the head . Does anyone know what stud threads go into the head and what size the threads for the exhaust threads for installing exhaust?
17 Jun 2021 07:11 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Looks like it might be one of they funny ones - M6 in the cylinder and M8 for the flange (see photo).
Dimensions of screws and bolts are often (but not always!) included within a part number.
The following user(s) Liked this Post: Patroll330
17 Jun 2021 07:34 #2
  • Patroll330
Bolt, Stud part # (392-14651-00) 90116-06146-00  is the part number just doesn't mention thread sizes .
Last edit: 17 Jun 2021 10:45 by Patroll330.
17 Jun 2021 10:40 #3
I think its just a common 6mm stud & nut. 6x1 pitch thread. No 3 & 5 in the link.
berkeleyhondayamaha.com/Parts/OEM-Parts-...00-0000-047337491974
18 Jun 2021 03:33 #4
  • Patroll330
Thanks never heard of Berkeley ,I used Babbits site looks similar. Thanks its a bummer not to have the size, some say 6M pitch 1
18 Jun 2021 18:56 #5
That part number is the stepped stud that Alan showed earlier.
Small end that goes into cylinder is 6mm x 1.0 pitch.
Large end that takes nut is 8mm x 1.25 pitch.
19 Jun 2021 08:01 #6
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=123327009133&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Now this is funny stuff... I found a 6 volt horn for a VW... Its now mounted on my trail90! Talk about "inter changeable stuff"!
Sneezles61
19 Jun 2021 14:39 #8
Those VW studs are for the oil drain plate underneath the engine that accesses the screen.  The little 6mm studs get overtightened and strip out of the case.  Then you drill/tap to 8mm and install the stepped studs.  I think they are too short for Yamaha exhaust studs but they did make a similar "repair" stud for the VW intake manifold that should work as it's longer.
The following user(s) Liked this Post: Bdubya, Patroll330
19 Jun 2021 15:02 #9
  • Patroll330
Yes , these are the correct threads sizes per each side of stud. Thanks
26 Jun 2021 13:02 #10
