DT400 twin shock front plastic mudguard (fender!)
- Jammyyammy
DT400 twin shock front plastic mudguard (fender!) was created by Jammyyammy
Hi - my DT400 has been in an accident or two (previous owners !!!).
As a result, the front plastic mudguard (fender!) is mis-shaped. It looks like it has been really twisted/bent in two in a few places.
The sides aren’t straight.
I’ve seen all the you tube clips using a hot air gun to re-shape plastic, but has anyone actually tried a similar job on one of these mudguards (fenders!)?
I thought that I would ask before I turn a half-reasonable mudguard (for the last time, fender!) into a melted mess rather than afterwards.
Thanks.........
Thanks.........
- Wessi
Replied by Wessi on topic DT400 twin shock front plastic mudguard (fender!)
Hi Jammyyammy,
heat gun seems to be the only way. Yor fender doesn´t look too bad, at least it´s not broken anywhere. Mine was in worse condition. The dosing / distribution of the heat is tricky.. Better to chose mid range of a heat gun and carefully heat mostly center of the bend and surrounding areas little less. With gloves, a little overbend in the other direction and hold it, until its cold.. If you hit the right point, you will see then. If not, try again. Beside some bendings, mine was twisted, too. Here i heated the fender over the whole width and twisted in the other direction until its cold. Dont overheat, it will melt.. Good luck.
30 Apr 2021 09:16
- Jammyyammy
Replied by Jammyyammy on topic DT400 twin shock front plastic mudguard (fender!)
Thanks Wessi - I’m going to give it my best shot.
I sent photo’s / details to dream machine uk, asking them for a price to repair and respray. They responded by asking me to find a better example. I wish...
30 Apr 2021 11:39
- Pete-RT1
Replied by Pete-RT1 on topic DT400 twin shock front plastic mudguard (fender!)
Jammy
Take a look at this post www.yamaha-enduros.com/index.php/forums/...rear-fender?start=20
If you have no luck then you can get a repop.
Pete
Pete
Yamaha CT3 (in bits)
- Jammyyammy
Thanks for that Pete - that’s a lot of really good info. Has anyone out there got recent experience with the reproduction plastic front mudguards (fenders)? Are they any good? Which are considered the best? What about the ones from eBay/Thailand?
Also, does anyone have experience with spraying them (silver spray on a white one...).
Many thanks.....
Many thanks.....
30 Apr 2021 13:27
- Wessi
Had purchased one from Thailand. They fit but they are much shorter than OEM, think about 6-7cm front and 6-7cm backside. Width aproximately fits. After painting and installing it, for me the side view of the bike was spoiled, so i looked for an original fender and restored it with a heatgun.. The result after 1-2 hours of heating and bending was excellent
01 May 2021 00:37
- Schu
Replied by Schu on topic DT400 twin shock front plastic mudguard (fender!)
Here is an option if your repair doesn't work out. I saved this link because I had thoughts of getting one for my DT400B. It is made in my home state of Michigan.
www.dcvmx.com/xcart/product.php?productid=18415&cat=282&page=1
01 May 2021 06:36
- Jammyyammy
Thanks Schu - probably better quality (and more likely to be the correct dimensions) than the one from Thailand. I’ll ask them for a cost for shipping if mine turns out bad.
Thanks Wessi - I have one quick question - if I don’t get the plastic perfectly straight (every little undulation would show when it’s sprayed silver), is it possible to fill the low spots and rub down the high spots - like you would do on a metal mudguard (fender!) - before spraying?
01 May 2021 07:53
- Schu
If you do go with DC Plastics, read thru the "About Us" tab where he describes their process compared to others.
www.dcvmx.com/xcart/pages.php?pageid=11
01 May 2021 09:11
- Wessi
...sure, you can use special plastic putty (remains somehow flexible) and sand the remaining dents.
I didn´t have any problems with cracks in the putty.
02 May 2021 00:41
