Dt400 twin-shock carburettor tuning
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
Dt400 twin-shock carburettor tuning was created by Jammyyammy
Hi all,
Does anyone know of a good video or write-up on setting a DT400 twin shock carburettor?
I've got the bike running after fitting a Rex Speedshop ignition.
I've set the A/F screw at 1.5 turns out, but am slightly confused about what to look out for when setting the other screw. I've set the needle height to stock.
Also, what should the tickover/idle rate be?
Many thanks......
10 Apr 2021 13:44 #1
Replied by MarkT on topic Dt400 twin-shock carburettor tuning
Other screw is a throttle stop screw.  You set the idle speed with it.  Turning it in (clockwise) raises the slide and the idle speed.  Manuals in Tech Library have the specs and the procedures if you're still not sure.
10 Apr 2021 21:16 #2
Replied by DT Tim on topic Dt400 twin-shock carburettor tuning
There's some good reading and info in this thread.
yamaha-enduros.com/index.php/forums/74-7...up-to-snuff?start=30
10 Apr 2021 23:56 #3
