Exhaust o'ring
  • peteyam54
  • peteyam54's Avatar Topic Author
Exhaust o'ring was created by peteyam54
Hello, I'm missing the o'ring that goes between the silencer and exhaust on my DT250A (p/n 9321027250). Anybody know where I can get one, or can tell me the diameter so I can try and source a replacement. Thanks
08 Mar 2021 10:20 #1
Replied by Gr8uncleal on topic Exhaust o'ring
If you are in the US, this is on your fleabay.
NOS YAMAHA O-RING YT125K GT80 DT360 DT125 93210-27250 OEM | eBay
08 Mar 2021 10:31 #2
  • peteyam54
Replied by peteyam54 on topic Exhaust o'ring
Thanks for the response - unfortunately I'm in the UK and I really can't justify £40 for an o'ring. I'm sure if I can get the measurements, I can find something suitable? Cheers
08 Mar 2021 11:34 #3
Yes, ditto!
If you have both parts of the exhaust, can you not work out the dimensions yourself? I would imagine that the external diameter would be about 1mm larger than the internal diameter of the exhaust and the internal diameter about 1mm less than the external diameter of the groove in the tailpipe that it sits in.
08 Mar 2021 12:09 #4
Replied by DEET on topic Exhaust o'ring
I think I have some if you can't find what you need.
08 Mar 2021 12:14 #5
Just had a moment of perspiration, I mean inspiration (
) and have had a look at my original parts book. This shows dimensions as "3.1 - 27.4". The first number is the section area (thickness x 2?) and the second is the internal diameter, both in mm. However, I'm not certain of this interpretation, so would like others to confirm. It could be, from the part number, that the external diameter is 27mm and the internal 25mm.
Last edit: 09 Mar 2021 04:37 by Gr8uncleal.
08 Mar 2021 12:18 #6
  • peteyam54
Thanks - that's really helpful. I'll check measurements to see if that confirms size. I thought I'd found a perfect o'ring to fit the end pipe but it was too thick to go into other end - so it needs to be fairly thin (and presumaby made of a heat resistant material too). If that fails, I might try DEET's offer! Cheers
09 Mar 2021 00:55 #7
I think that I've managed a half decent scan of the relevant page, so that you can see what I'm talking about.
The REALLY observant amongst you will notice the different badge on the exhaust - it is a parts book for the European models.
09 Mar 2021 04:44 #8
If you do go the DEET route, just see if he has anything else that you need, so that you aren't paying postage for just one item.
09 Mar 2021 04:49 #9
Replied by Pete-RT1 on topic Exhaust o'ring
Alan, o-rings are typically specified by section and internal diameter.
Looking at your manual I would say it is 3.1mm section with 27.4mm ID.
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
09 Mar 2021 13:56 #10
