ROTORS , FOTO1971 VS F1T350.
  • Jewelkutter
  • Jewelkutter's Avatar Topic Author
Replied by Jewelkutter on topic ROTORS , FOTO1971 VS F1T350.
Im not actually sure if the drilings in the side of the flywheel are for ballancing it , im only assuming that. I also found another FOTO1971 tha only had 4 drillings , it did have the shouldered edge and the seller did say it came out of a 74 DT250A
28 Mar 2022 15:00 #11
Replied by MarkT on topic ROTORS , FOTO1971 VS F1T350.
In the 1974 redesign of the 250/360, the case opening the flywheel spins inside was made smaller...  just small enough that the 73 and earlier flywheel will just barely rub the 1974-on case.  I've always thought that might be why the step was machined in the 74 models?
And pretty sure the holes are balance holes.
28 Mar 2022 17:23 #12
  • Jewelkutter
Thanks MARKT, I was just thinking about the rotor again and what you said about the flywheel being machined on the edge for clearance, I haven't tried the rotor yet but it should be clear?, when I do, if it rubs or not that being said if it does rub it would have to be from an earlier model? I did manage to stitch the broken wire on the lighting coil back together not sure if it will work, but trying anyways
25 Jul 2022 16:07 #13
  • Jewelkutter
25 Jul 2022 16:12 #14
  • Jewelkutter
Can't really see it all that great but I twisted the 2 ends back together
25 Jul 2022 16:13 #15
  • Jewelkutter
25 Jul 2022 16:17 #16
Replied by Ht1kid on topic ROTORS , FOTO1971 VS F1T350.
From your picture it looks like your points rubbing block ( heal ) is worn down maybe just the angle of the picture
25 Jul 2022 16:42 #17
Replied by RT325 on topic ROTORS , FOTO1971 VS F1T350.
Me too, & looks like fiber block is totaly missing. Hope it's just my screen. & i'd missed seeing it first time around--blind as a bat 'me'.
Last edit: 25 Jul 2022 20:56 by RT325.
25 Jul 2022 20:54 #18
  • Jewelkutter
Last edit: 26 Jul 2022 16:26 by Jewelkutter. Reason: Somehow i got it in the twice
26 Jul 2022 14:34 #19
  • Jewelkutter
Yes , points will be replaced , not sure about the condenser. I have new engine gasket kit and the left crank seal so far I haven't really started working on the engine yet , not sure what it needs yet . I'm just about done with the bike reassembly , powdercoated frame and all the black parts still have to get kick stand and bash guard powdercoated , put some new shinko tires, i used 3 screwdrivers to do that job , happy with that. found a good used rear rim on eBay .
I've never taken apart a Yamaha engine , done a few triumph 650's can't be anymore of a challenge than they were , it's all fun. I was wondering about the exhaust , someone told me to light it on fire to burn out the carbon , not sure about that. I got a new wiring harness , very nicely made from endurodoctor, I think ?  Got a new seat pan and foam from kdi and the cover from up north nicely made  it came out good , ive got the carb apart and clean need the air filter still . Any pointers on my engine dismantle greatly appreciated.
thanks
26 Jul 2022 16:25 #20
