Starter Dynamo and Voltage Regulator
- apex
- Content Contributor
Replied by apex on topic Starter Dynamo and Voltage Regulator
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=254786788070&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- StukaGruppen13
Replied by StukaGruppen13 on topic Starter Dynamo and Voltage Regulator
Thanks for the help so far, going to connect my dark green to black, make sure my meter is on DC (pretty sure it wasn't before!) and see what's what.
07 Jan 2021 08:38
#12
- StukaGruppen13
Meter on DC, and no voltage. Looks like I'll buy some brushes and try again.
07 Jan 2021 09:32
#13
- apex
You can get a pretty good idea of how worn they are by comparing to the Singapore eBay photo. The line in the brush about mid-way is a "wear limit point," and just about every AT1 that I've had to dig into the Yoke for charging problems, the brushes are stuck/sticking in their guides and the brush is at the wear limit or past it. You'll need to clean the mica on the rotor, and there are plenty of posts on You Tube and this site for that process, it's not hard.
Allrighty Then
The following user(s) Liked this Post: StukaGruppen13
07 Jan 2021 17:30
#14
- StukaGruppen13
Did all the dynamo tests in the manual last night, and I'm getting continuity between positive and negative brushes. I ordered those UK brushes, so once they come in I'll replace them and fix the insulation between the brushes, then I think I'll have voltage. Once I get it down there I can check the regulator and battery, I think it might be suspect as well.
08 Jan 2021 08:29
#15
- StukaGruppen13
Update for anyone else having this issue in the future: a screw holding a brush lead was too long and grounding out by bottoming in its hole. Super simple, now there's voltage!
The following user(s) Liked this Post: Newguy123
17 Mar 2022 05:54
#16
