Blind plug leaking oil
- treeves
Blind plug leaking oil was created by treeves
I posted I was finally finished with my DT 360 a couple of months ago. I think most of you new that was not true. I have gotten the oil leaks fixed except for the blind plug is leaking a little oil, I can not find a new one so is there any way to stop the leak.
16 Sep 2020 09:31
Replied by MarkT on topic Blind plug leaking oil
1974 DT360?
Yamaha still sells them... shouldn't be hard to get.
#19 here: www.partzilla.com/catalog/yamaha/motorcy...974/dt360a/shifter-1
I would buy from RMATV-MC... but linking to their specific parts pages directly doesn't work.
16 Sep 2020 16:31
Or wait, is that the bigger plug over the end of the shift drum they used on some models?
Kind of looks that way at second thought...
16 Sep 2020 16:37
- treeves
Replied by treeves on topic Blind plug leaking oil
Number 7 on Partzilla.
16 Sep 2020 17:32
If you can carefully remove it, apply some Yamabond, and reinstall, it would probably seal.
But what always tends to happen to me is that the leak is somewhere else... especially under the output shaft which really isn't sealed all that good. Can you clean it up real good.... let it sit until it looks like it's leaking... then dust the area with baby powder or flour? Often that technique will show you exactly what's seeping and where. Leak could be coming from up higher and running down.
16 Sep 2020 20:52
- yamahahaha
Replied by yamahahaha on topic Blind plug leaking oil
Hey Mark.
I did not know you worked in CSI
17 Sep 2020 04:27
- treeves
Thanks Mark T I will try the baby powder. How would you take the blind plug out?
17 Sep 2020 07:49
