dt 400 headlight
  • greens8
  • greens8's Avatar Topic Author
dt 400 headlight was created by greens8
Have converted dt400B to 12 volt, are there any options to just replace the standard sealed 6v unit or will I have to replace the whole assembly?
06 Sep 2020 00:47 #1
Replied by Gr8uncleal on topic dt 400 headlight
Apologies if I've asked this already, but what part of the world are you in?
06 Sep 2020 01:07 #2
  • greens8
Replied by greens8 on topic dt 400 headlight
No problem it`s near Sydney, Australia
06 Sep 2020 01:31 #3
Some of those sealed beams can, with care, be dismantled - those are the ones with 5 or 7 tangs holding the bulb in place. There are a couple of threads on the forum on this.
Personally, I'd measure the headlight assembly and then see which models in your part of the world with a replacement bulb capability were the same size - something like the RD125/200 spring to mind. I guess you could buy one from the UK if the postage isn't too penal.
If the headlight is in a fixed position in the chrome outer ring, make sure that the mounting hole from the ring to the headlight matches up.
Finally, you may well find some companies sell a generic headlight unit in the size you need.
06 Sep 2020 02:00 #4
Replied by Wessi on topic dt 400 headlight
Hi,
you just need a reflector, which fits into your bowl. The diameter 5 3/4" should fit, just type 5 3/4 in search of Ebay Australia. Of course this reflector should have the bulb holder, you need to be street legal. Dont know what this is in your country.
You could buy a reflector, look if it fits. If not, just send it back.
Regards from Germany
06 Sep 2020 05:00 #5
Replied by MarkT on topic dt 400 headlight
In Australia does the bulb come out of the reflector? If so, you should be able to find a bulb.
If it's a "sealed beam" just remove the entire glass bulb/reflector/lens assembly and replace with a 12v automotive light. VERY common.
H5001 is a common part number. You install it into your chrome ring. There are also versions with H4 replaceable bulbs.
What you're getting is a bulb that looks like #6 and that is held in by clips #17.
06 Sep 2020 08:54 #6
Replied by turbodan on topic dt 400 headlight
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=261207462566&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by yamahahaha on topic dt 400 headlight
Can you post pictures of it in your DT360 ?
08 Sep 2020 09:11 #8
  • greens8
Wow that`s all really good info guys. I have bought a replacement should be the same dimensions and I`ll spray it silver, see how it looks. If its not right I will replace it, not worried about price until everything works perfectly. I haven`t taken the original lens apart yet, but I will tonight. (Mine`s a 75 400B not a 360 )
12 Sep 2020 00:09 #9
Hopefully the pics attached to this post
13 Sep 2020 12:45 #10
