Auto Lube Banjo Bolt
  • RustiePyles
  • RustiePyles's Avatar Topic Author
Auto Lube Banjo Bolt was created by RustiePyles
Looking for the part# for the banjo bolt and two washers that attach the auto lube hose to the bottom of the cylinder on a DT175B. can't seem to find them in my parts book.
Fletch
1975 DT175B
1979 XS650
28 Aug 2020 06:18 #1
  • RustiePyles
Replied by RustiePyles on topic Auto Lube Banjo Bolt
Yep, that's it. thanks Mauser. My drawing shows everything but the bolt and washers. Every time I tried to keyword search them I just come up with brake system banjo bolts for yamaha's.
Fletch
1975 DT175B
1979 XS650
28 Aug 2020 07:54 #2
Replied by asco on topic Auto Lube Banjo Bolt
214-13162-00-00 banjo
You probably can use Felt, Aluminum or Copper Washers.
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 28 Aug 2020 16:53 by asco.
28 Aug 2020 14:44 #3
