1975-76 DT400 fork oil weight?
- Bigdog302
- Topic Author
1975-76 DT400 fork oil weight? was created by Bigdog302
getting ready to rebuild the forks on the forks on the Super DT400 and I am wondering what weight fork oil you are running in your forks on mid 7 0's DT400s?
also what aftermarket fork springs do you suggest? I am planning to rebuild them with a Trick-IT fork kit I have.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
- Shane86
Replied by Shane86 on topic 1975-76 DT400 fork oil weight?
I am running 10 weight and springs from race tech. I believe that are the same springs as the ttr125. At least the 74 DT250 is listed on the race tech site which should be the same springs as your 400. I did have to turn down the upper spring retainer to make the springs fit.
04 Aug 2020 11:00
- Bigdog302
- Topic Author
Replied by Bigdog302 on topic 1975-76 DT400 fork oil weight?
Thanks Shane! I will give that a try!
I found this page and they even list a setup there. www.racetech.com/ProductSearch/12/Yamaha/DT400/1975
Why did I not think of this?
Dave
Jesus is Lord!
Dave
Jesus is Lord!
- Bigdog302
- Topic Author
In other news, I got both front and rear new tires on the RT1B.
I started modding a stock pipe for my 1978 DT175E
Dave
Jesus is Lord!
Dave
Jesus is Lord!
07 Aug 2020 17:41
- Bigdog302
- Topic Author
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=312586584814&version=889&trackingid=&trackingpartnercode=9): failed to open stream: Connection refused. Please enable debug mode for more information.
- Shane86
I looked back at my notes and see I changed to 200cc 15w last change with the new springs. I don’t have much run time on this setup. I race vintage MX with this bike and weigh about 180 for reference.
10 Aug 2020 05:42
- Bigdog302
- Topic Author
I will need to run the heaviest springs due to my weight and The Trick -it fork kit says to run 30 weight for fork oil. I guess I will start there and work from there. Racetech has springs for my bike.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
