DT360 autolube banjo bolt broke.
- mdscott
DT360 autolube banjo bolt broke. was created by mdscott
DT360 autolube banjo bolt broke, the issue is the DT360 does not use a banjo (union) bolt at the pump. So Im thinking I may not have the correct pump. If someone could take a pic of theirs I can verify its right or wrong. Also I discovered the spring and check ball are missing.
Other bikes like the RT3 uses and union bolt.
214-13162-01-00
www.rosevillemotorsportsparts.com/oempar...209bc7849ca/oil-pump
214-13162-01-00
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
- mdscott
Replied by mdscott on topic DT360 autolube banjo bolt broke.
I might try this off my YG5T, try to adapt it. . The part is on backorder. It broke getting bike ready to take to Socal.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Jul 2020 16:51
Replied by MarkT on topic DT360 autolube banjo bolt broke.
I've seen Yamaha use different parts than the parts list shows.
I probably have a spare banjo fitting I can mail to your house or to So Cal?
09 Jul 2020 17:02
- mdscott
Wow mark that would be fantastic. I can text the address to your phone.
I found a check ball and spring, does that keep the oil hose from the cylinder draining back to the pump?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Jul 2020 17:28
- mdscott
Ive seen a spec sheet that shows all of the Autolube pump specs, if anyone has i would you be so kind as to post it. Ill look on tech library.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Jul 2020 19:18
Yes and I think it's also is supposed to keep the oil from the tank from freely siphoning into the engine when parked.
09 Jul 2020 20:02
- mdscott
Big shout out to MarkT, he had a banjo fitting, it’s currently in the mail. I also found out the pump that’s in the my bike is for a RT, I believe. The marking on the pulley wheel has “RT”.
Thanks again Mark
Thanks again Mark
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
10 Jul 2020 07:43
