Do Motor gasket sets for later Models on DT250B ?
  • Wessi
  • Wessi's Avatar Topic Author
Hi all,
bougth a set including Zylinder, Zylinder head, clutch cover, magneto cover, inlet and outlet on Ebay.uk. Anounced specially for DT 250 `75-76. The only gasket that fits was the oil pump gasket, but i purchased it 9month ago, so no chance to send it back. Guess it was from maybe DT 175. As i can not find any other supplier for ´75-76 sets, but mostly for ´78-79MX models i wonder, if those all or mostly fit on Twin Shock bikes. Any experiences from you? Thanks for help in advance
Last edit: 30 May 2020 02:01 by Wessi.
30 May 2020 02:00 #1
Are you in the US, UK, or somewhere else?
30 May 2020 03:21 #2
Replied by Gr8uncleal on topic Do Motor gasket sets for later Models on DT250B ?
I think Wessi is in Germany.
30 May 2020 07:22 #3
www.cruzinimage.net/2017/11/14/1977-1982...x-engine-gasket-set/
Try these guys. Didn't see 1975 but they might have them
30 May 2020 08:36 #4
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=401614216277&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Wessi
Yes, i am living in Germany.
@Yamhopa, this is exactly the set , I bought. None of this gaskets fit on a DT250B, except the tiny oil pumps gasket. But lots of MX sets are available, therefore my question. If there would be one or two in the set which not fit, I could buy them separately...
Regards, Guido
31 May 2020 08:20 #6
Yes MX part numbers are the same. Look at any yamaha parts dealer schematic. www.rockymountainatvmc.com/oem-schematic/4. I would contact the seller on E bay. Explain your concern about his kit not fitting. Getting the correct one from them will be a lot cheaper than oem Yamaha.
The following user(s) Liked this Post: Wessi
01 Jun 2020 10:17 #7
The 1977 part numbers are different. So tell the seller he may have sent you a 1977 set.
01 Jun 2020 10:26 #8
