DT360A intake hose clamps
  • Gr8uncleal
  • Gr8uncleal's Avatar Topic Author
DT360A intake hose clamps was created by Gr8uncleal
Does anyone know if there is a Yamaha alternative to the now discontinued intake hose clamps? Original part number was 308-14455, supersession to 90460-54062.
If forced into a corner, I could use jubilee clips. However, I would prefer something that at least looks original.
I could be persuaded into buying a used pair from the US if the price and postage was reasonable! :haha
Many thanks.
Alan
18 May 2020 06:14 #1
Replied by mdscott on topic DT360A intake hose clamps
Reading your plea, I ran out to my garage and took a look. I have a set but it’s for a SC500, larger diameter, darn.
I do have a set from my CB500, they look similar but I’m not sure if the diameter Will work.
Max opening, 51mm, closed-47mm.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Last edit: 18 May 2020 08:37 by mdscott.
18 May 2020 08:35 #2
  • Gr8uncleal
Replied by Gr8uncleal on topic DT360A intake hose clamps
Thanks.
I'll go and have a measure up after tea.
I can't believe that Yamaha continue production of some clamps but not others, and also that the dimensions aren't shown like on a load of other parts.
Looks like there should be a couple of kinks in the item, to enable the "inner" element to go under the "outer" upon tightening. I've got some clamps that might work, but I'd have to put the kinks in myself - not impossible by any means, but my preference is normally for the correct part.
18 May 2020 08:44 #3
the clamps are soft, bend easy
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
18 May 2020 10:36 #4
