Oversize piston set for dt400
- RobertE
Oversize piston set for dt400 was created by RobertE
Does anybody know if there is an 87mm piston kit made for a 75 dt400? Stock is 85mm and all I've been able to find so far are 85.5, 86.0, and 86.5. 87mm would be 4th overbore.
13 May 2020 09:24
Replied by MarkT on topic Oversize piston set for dt400
Check with Enduronut, he probably has one.
13 May 2020 10:58
- RobertE
Replied by RobertE on topic Oversize piston set for dt400
how do you get ahold of him?
13 May 2020 11:17
- yamahoper
Replied by yamahoper on topic Oversize piston set for dt400
The pistons go + .25mm 1st over. so 86mm is 4th over. You can see this on the partzilla parts list
13 May 2020 11:29
- yamahoper
That is for Yamaha
Wiseco goes .50mm per over so their 3rd over is 86.5mm
That is the largest they list for a 1976 DT400
They are hard to find and probably not made anymore. Enduronut recently posted that he had at least one...
yamaha-enduros.com/index.php/forums/fng-...0-87mm-piston#102083
You can try to PM him... or if you search the forum for Enduronut I think you'll find his email.
13 May 2020 11:53
- LHA
Replied by LHA on topic Oversize piston set for dt400
I have a Wiseco 87mm piston kit. I'll go look and make sure that it's the size I think it is and get back later. I have a hogged-out jug as well,just needs bored.
LHA
13 May 2020 12:57
- LHA
I found the jug and head,I think from a 400 mx,but couldn't find the piston. I am an old fart and tired from rebuilding my '41 Ford tractor,but will look tomorrow when I'm not worn out.
LHA
13 May 2020 14:09
- RobertE
I can relate to the old fart and working on old iron. Any help would be appreciated. My other alternative is to go with the light pitting in the cylinder and hope.
14 May 2020 04:53
- LHA
I found it. It's a 87mm Wiseco with rings and pin retainers,but no pin. I gave $115.00 for it and will sell it for that. It is new old stock 400 MX '75-'78 models. I have a MX jug and head to match,just needs final honing/boring.
LHA
14 May 2020 08:33
