1975 dt400 wiring
Replied by AT6 DRIVER on topic 1975 dt400 wiring
Here is a photo of the black jumper inside the headlight. - the yellow ring terminal with the black wire. under the bolt.
1975 DT 400B
If it moves and shouldn't , use duct tape. If it doesn't move and should, use liquid wrench.
The following user(s) Liked this Post: STEVEN63
19 Feb 2015 18:54 #11
  • STEVEN63
  • STEVEN63's Avatar Topic Author
Replied by STEVEN63 on topic 1975 dt400 wiring
Yes, the wiring diagram would clear things up, but the service bulletin definitely says to tie in to the blue wire before headlight, which makes sense, since we are trying to protect the headlight bulb. also a separate grounding wire to frame if mounting on air box.
20 Feb 2015 04:00 #12
Here is the regulator mounted on the back of the headlight with the y connector I added instead of a splice into the ground wire.
1975 DT 400B
Last edit: 01 Apr 2015 19:59 by AT6 DRIVER.
01 Apr 2015 19:12 #13
Replied by Travis on topic 1975 dt400 wiring
How do I wire up my 1975 Yamaha dt400 without a CDI box
31 May 2021 09:24 #14
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1975 dt400 wiring
Has it been converted to points using the DT250 set up? If yes, then I think that DEET on this forum (This email address is being protected from spambots. You need JavaScript enabled to view it.) can supply a plug in and play conversion mini harness (I got one from him for my DT360A).
31 May 2021 09:45 #15
No it hasn't been converted . It has all original parts on it no headlights or accessories. Just want to know how to wire it without the CDI box?
31 May 2021 09:49 #16
  • Gr8uncleal
How will you get a spark without the CDI box?
Last edit: 31 May 2021 10:09 by Gr8uncleal.
31 May 2021 10:08 #17
Yes and do you have a good wiring diagram?
31 May 2021 10:20 #18
Got any ideas? It's got to be pretty simple I just can't figure it out. Need HELP
31 May 2021 18:25 #19
Replied by MarkT on topic 1975 dt400 wiring
Either we don't understand what you are asking or you don't understand what you are trying to do.
Might as well ask how to get the engine to run without a spark plug...  or get spark without an ignition coil.  CDI box is a critical part of a CDI ignition system.
The following user(s) Liked this Post: Swoop56, Starrblade
31 May 2021 18:52 #20
