Crankshaft Welding
  • Silo7
  • Silo7's Avatar Topic Author
Crankshaft Welding was created by Silo7
Upon disassembly for rebuild, I came across an odd situation and am seeking opinions. 76 DT 400 purchased, not ‘the one’ but regardless I will rebuild. During tear down, I pulled the flywheel, stator plate, etc. when placing the flywheel on tray, a sharp stabbed my hand. Upon closer inspection, the sharp was a piece of MIG wire. It appears that for some reason PO put a couple spots of weld on the taper of flywheel. The only reason I can think of is that the flywheel was loose and damaged the taper both wheel and shaft. Close inspection doesn’t show any excessive damage to shaft or flywheel. Although the 2-3 small spots of weld damaged the system, it appears that I can clean up and run with it.
Pictures attached are these I can give, any opinions or advice is greatly appreciated.
13 Apr 2020 08:19 #1
Replied by Pillsbury on topic Crankshaft Welding
PO's do strange things. I think once you clean it up & LAP it to fit you'll be good to go.
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
13 Apr 2020 10:43 #2
