Spoke Invoked Nightmares
- downsouthoutwest
Spoke Invoked Nightmares was created by downsouthoutwest
Hello,
I did one of the dumbest things I've ever managed last week. I had decided to replace my front and rear spokes, they had been sprayed gold and were rusty. I started undoing them individually, then at some point got bored, my brain switched off and I decided to angle grind every single one off. It was only when I'd removed them all, I realised I now had no idea what size or angle my replacements would be. What an idiot. Never embark on something at 1am after a long day!
I can lace and true them myself, but I need to order spokes. Does anyone know the lengths and angles required for a '76 DT175? Front is Takasago 1.60x21 6H 205, Rear is Takasago 1.85x18 6H 209.
I did speak to a wheel builder, but I don't get the rims / hubs back from powdercoat from another week and I'm pretty keen to order spokes now before Armageddon sets in.
Thankyou thank you thank you
26 Mar 2020 06:58
- 2fishkev
Replied by 2fishkev on topic Spoke Invoked Nightmares
I guess it all depends...... are you ordering from Buchanan’s? Are you wanting OEM? If Buchanan’s, I have no experience. Others have and will be along. If OEM, I get on Partzilla and look it up and then cross reference what other bikes use the same and then search eBay. They might still have them too for a reasonable price. Be warned though, spokes are one thing they try to gouge you on. 40-60$, ok. 100$, forget it! Even the Asian suppliers are pulling that sh%t. Good luck.
Did ya happen to measure offset before the gorilla struck? If not, after truing, bolt up to bike and make a centering stick and adjust for centering, then retrue. A friend told me that.
The following user(s) Liked this Post: LongStride
26 Mar 2020 07:22
- downsouthoutwest
Replied by downsouthoutwest on topic Spoke Invoked Nightmares
I'm based in the UK, so neither PartZilla or Buchanans are an option, unfortunately. I emailed Partzilla anyway and they have no stock. Ebay might be best bet. There's even a set of wheels for sale I'm considering buying them and restoring the spokes myself...
Nice note about centering, exactly what the wheel builder told me. Oh how much easier this would have been if I had gone around spoke for spoke...
O
O
26 Mar 2020 07:37
- 2fishkev
I hear ya, brother. What about cmsl? Also, think they were common with TY s, so maybe someone in your well supported trials community.
Ok, partzilla says different rim, 1.40”, different hub. But, they show as using the same brake shoes. So maybe.
- mdscott
Replied by mdscott on topic Spoke Invoked Nightmares
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=282593266392&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- 2fishkev
Sweet jumps.....
26 Mar 2020 08:03
- mdscott
3 feet of air or less and you'll be fine,
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
26 Mar 2020 08:19
- pabdt
Replied by pabdt on topic Spoke Invoked Nightmares
I used Buchanan spokes. As I remember, they seemed to have a working knowledge of the spoke requirements for my wheels though I did initially give them dimensions on my original spokes.
Though you can 't order maybe call for info?
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
27 Mar 2020 23:20
- Eazy-X
Replied by Eazy-X on topic Spoke Invoked Nightmares
Bit more expensive but I recommend:
Devon Rim Company
My spokes were rusty to the point of collapse and went with stainless steel over zinc.
Fronts for stock rims are 100% definitely 10 gauge with .225" nipples. There was some debate over the rears though. The thread ends definitely need to be 10 gauge / .225" but the hub end should probably be 9 gauge (tapered) but that would have made it into a custom order so I stuck with 10 gauge throughout... not aiming to do any "sweet jumps" so shouldn't be a problem
You only need a few spokes as samples to send them to verify if you're not sure. Thankfully I got enough intact ones off before breaking out the bolt cutters!
Devon Rim Company
- DaveR
Replied by DaveR on topic Spoke Invoked Nightmares
Hope this helps, for scale the ruler is 1 inch wide, ( add 1" to the 19" spoke length )
The following user(s) Liked this Post: FrankC, Camp3
28 Mar 2020 08:20
