DT250A Engine Bushing/Damper Removal
  • Camp3
  • Camp3's Avatar Topic Author
So today is a cold overcast day in Chicago area and is a good day to work on my DT250A teardown. I am well along and see the engine dampers are quote old and cracked. I was able to get one of the two out but it seems there must be a better way than pounding and beating it out. I used heat, Kroil, chisel, homemade puller etc. Is there a way you guys get these older dampers out? Once its out I have to get a new one in without ruining it as well.. Any suggestions would be very helpful.
Here's the bad one I was able to remove
and my home made case splitter with Harbor Freight Puller remover..(yes its crude)
1976 DT175C
1975 DT100B Kid Trainer
1974 DT250A In Process
1992 FJ1200
14 Dec 2019 15:17 #1
Replied by 1971DT250 on topic DT250A Engine Bushing/Damper Removal
I've done several like that by using a scroll saw with a metal cutting blade. Unhook the blade from the handle/frame, insert the blade through the hole, attach the blade to the handle and cut slowly through the bushing. It will pop out easy.
14 Dec 2019 16:33 #2
  • Camp3
Replied by Camp3 on topic DT250A Engine Bushing/Damper Removal
Thanks!, I'll give a shot...
1976 DT175C
1992 FJ1200
14 Dec 2019 17:17 #3
Replied by Trigbe on topic DT250A Engine Bushing/Damper Removal
I am in Geneva. If you want to bring it down here I can turn a piece to drive it out with a press and make a install tool for installing the new one if you have it.
Trig
17 Dec 2019 20:33 #4
Replied by nhsteve on topic DT250A Engine Bushing/Damper Removal
Can you actually get the new bushings? Where did/do you obtain?
19 Dec 2019 06:11 #5
  • Camp3
partzilla indicated they have them in stock for $20 each, I thought I would cannibalize some from another case I have if I got desperate.
1976 DT175C
1992 FJ1200
19 Dec 2019 10:12 #6
  • Camp3
Thanks Trig, I think I might just leave the other one alone...for now :)
1976 DT175C
1992 FJ1200
19 Dec 2019 12:28 #7
No problem. Let me know if you need a installation tool
Trig
19 Dec 2019 12:40 #8
