74 DT250 Rear hub removal help
  • EnduroTEX
  • EnduroTEX's Avatar Topic Author
74 DT250 Rear hub removal help was created by EnduroTEX
I am removing both front and rear wheels for cleaning, inspection, fresh bearings/seals, relacing with fresh spokes and polishing hubs etc.. The front went smoothly and am about to start the relacing with everything looking good, replaced etc..
The rear has me stumped (first time effort here). I immediately noticed the bike had loose rear sprocket bolts and was already suspect of damage. Pic below shows that it clearly rubbed the center of sprocket our of round..... I have now removed the circlip but the Clutch hub as it is described on parts list wont budge. Is there a procedure for removal. The dampers may be shot underneath and it certainly would be easier to clean/polish and relace the wheel with this removed.... Before I start my well known "monkey boy" routine with a rubber mallet or worse i was hoping for a quick tutorial or recommendation..
Much Thanks!
14 Nov 2019 09:06 #1
  • EnduroTEX
Replied by EnduroTEX on topic 74 DT250 Rear hub removal help
Not sure why this pic did not load but here is the damaged sprocket..
14 Nov 2019 09:09 #2
Replied by Gr8uncleal on topic 74 DT250 Rear hub removal help
Check out the link to another thread below - the centre hole of the sprocket is meant to be out of round!
yamaha-enduros.com/index.php/forums/gene...cket-replace?start=0
14 Nov 2019 09:28 #3
  • EnduroTEX
Well Gr8uncleal- I am glad I asked and posted as I would not have guessed that!! Just read the other thread and it makes sense now with the circlip being accounted for in the engineering on this bikes hub setup. So no damage to the sprocket then but still- this hub seems it should come off easier after removing circlip .... hmmmmm.
14 Nov 2019 10:07 #4
You could try some gentle taps with your "persuader", or maybe spray some sort of releasing agent around it and leave it for a while.
14 Nov 2019 11:38 #5
Replied by pabdt on topic 74 DT250 Rear hub removal help
Flywheel damper puller will pull it straight off. I put a little pressure on it and tapped w/rubber mallet.I would be careful though as those sprocket holes could be easily stripped.
I just got done polishing that hub. Oh fun fun.
A pic with it removed and polished.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 15 Nov 2019 00:06 by pabdt.
14 Nov 2019 23:49 #6
  • EnduroTEX
Well a little PBblaster and some patience ( a tool which i rarely can find in the tool chest) and she finally came loose. Thank you guys. It appears there was a small metal burr of some sort that was hanging it up as well as just being old. Was able to get some things done to it today.
15 Nov 2019 14:52 #7
Great news, well done.
16 Nov 2019 00:07 #8
