1974 DT360A - grommet or no grommet?
1974 DT360A - grommet or no grommet? was created by Gr8uncleal
I'm slowly putting my DT360A back together and I was wondering if the locating lug on the airbox sits in a grommet within the hole on the frame? It seems to me like it should, but I couldn't see anything in the parts manual under either "intake" or "frame". A photo of the area that I'm talking about is attached.
I would imagine that the twin shock DT250s and DT400s up to 1976 would be the same.
Thanks.
Alan
Thanks.
Alan
30 Sep 2019 05:41
- KennyV
Replied by KennyV on topic 1974 DT360A - grommet or no grommet?
Hi Alan, no grommet. My 250A has a piece of rubber tubing on the pin. And like you, I couldn't find anything in the parts diagrams that show it.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
30 Sep 2019 06:12
- Steve F
Replied by Steve F on topic 1974 DT360A - grommet or no grommet?
I was fortunate to still have the orig, but in sad/ useable shape. I reinstalled it after painting the frame, carefully & it is still functional. Like Kenny I would have fitted a piece of rubber tubing if that was all I could find. Good Luck...
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
30 Sep 2019 07:37
Replied by Gr8uncleal on topic 1974 DT360A - grommet or no grommet?
Thanks chaps.
So the answer is that there may well have been one fitted originally, but Yamaha don't list it as a part?!
I have loads of rubbers and gromety type things lying around, so I can probably make a diy one.
Thanks again.
Thanks again.
30 Sep 2019 08:04
- run103
Replied by run103 on topic 1974 DT360A - grommet or no grommet?
take a piece of fuel line that fits the pin tightly and is to large for the hole it fits in and take a cutting wheel and cut a groove in the gas line so it stays in place. Actually is better than new because the fuel line is more durable. I also stretch a short piece of clear fuel line over the rectangular pin that the side cover fits on. Done this on at least 20 bikes and works well. Not factory but effective
Doug
Doug
30 Sep 2019 08:48
- Steve F
LOOKING thru my parts today I discovered I had 2 of these, AIR BOX MOUNTING GROMMETS, grommets. Checked out the prt no on e-bay & several are listed there. Cheapest NOS is $2.98 at Partzilla.com . You will find it on the 74DT175A part schematic under INTAKE.
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
The following user(s) Liked this Post: MarkT, KennyV, Gr8uncleal
05 Nov 2019 19:03
Thanks for this info Steve, most helpful.
To be honest, that's what I would have expected to see on the DT360A parts list. However, nothing present.
I've managed to fashion a reasonably functional item from one of the old grommets etc that I have hanging around. When I get a moment, I will look for a genuine one locally (I am in the UK). Just checked, and it is still available from Yamaha for £1.66 ($2.14 at time of typing).
Thanks again.
Alan
Thanks again.
Alan
The following user(s) Liked this Post: Steve F
