Timing question for '78 dt400
Replied by Blackhat250 on topic Re:RE: Re:Timing question for '78 dt400
Great news, , the figures MEIS says are good, , your plug is a little black, In the video" it looks like thers no air filter in , ? will run better if filter installed,
My DT250D runs around 370 degree,[ uphill] :OnFire
If you aint mixin gas " you aint haulin Ass
30 Dec 2015 15:23 #21
Replied by FrankC on topic Re:RE: Re:Timing question for '78 dt400
If you need side panel DC makes them in a matt finish polyethylene. Also front/rear fender. I believe you can clear them for a glossy look. www.dcvmx.com/xcart/product.php?productid=186895&cat=&page=1
31 Dec 2015 10:10 #22
  • Blackwidow824
  • Blackwidow824's Avatar Topic Author
Replied by Blackwidow824 on topic Re:Timing question for '78 dt400
Thanks frankc. I have the side panels, just didnt have them installed when I took the video
Sent from my SCH-I605 using Tapatalk
31 Dec 2015 14:20 #23
  • Blackwidow824
Replied by Blackwidow824 on topic Re:RE: Re:RE: Re:Timing question for '78 dt400
I hadn't even thought about gearing. I'm bet this bike is geared low by the previous owner because he raced it in hairscrambles I think.
31 Dec 2015 14:23 #24
  • Blackwidow824
The air filter is installed. I think you're seeing the airbox cover
31 Dec 2015 14:24 #25
Replied by Dave Schaub on topic Re:DT400! It lives! And wheelies!
what did you have for air leaks ?
31 Dec 2015 15:24 #26
  • Blackwidow824
Really big leak at the bottom of the intake boot. Apparently thays really common. I should just buy a new one but I made a gasket for it and used some Yamabond. That fixed it.
The following user(s) Liked this Post: FrankC, Dave Schaub
09 Jan 2016 15:38 #27
Replied by wicks on topic Timing question for '78 dt400
Can all three marks be aligned and timing still be off? (77dt400)
I am doing the 3.5 turns back, 1.1 turns forward thing, as well as the below method, and my flywheel which is properly on the woodruff, is about 1/2 inch before the crank mark and the stator marks (which are aligned). Using an inch (one inch divided into tenths) dual gauge.
A seemingly much simpler method than the bizarre procedure in the service manual: "you also need to "zero" your dial indicator too before attempting to read the timing. bring the engine up on top dead center and with the small hand at 5 mm and the large hand on 0, rotate the engine backwards to 2.9 mm is read on the dial indicator and check all 3 marks. they should be all aligned then."
13 Aug 2017 12:12 #28
Replied by DT400FRANK on topic Re:RE: Re:Timing question for '78 dt400
I'm getting temperatures of around 350 degrees also at my plug. Highest temp I got was like 380 degrees 1978 dt400
25 Oct 2022 15:35 #29
Replied by RT325 on topic Re:RE: Re:Timing question for '78 dt400
Can't go wrong with motors like that. Just put the back plate on where original screws leave a mark of having secured. Then flywheel on crank key & what can go wrong--unless something in the cdi box has gone wonky. Should be --or could be--a slight mark on the plate to align with a similar mark on the case, which in theory should align when original screw witness marks are used. That's providing someone in its life hasn't moved things all over the show & left marks everywhere. Be likely not far from center of the slots. Gives you a bit of room in the slots to play retarding or advancing if you wanted to & i guess check temperature reading which i should learn how to do.
Last edit: 25 Oct 2022 16:18 by RT325.
25 Oct 2022 16:18 #30
