My first mono-shock
  • Schu
  • Schu's Avatar Topic Author
Replied by Schu on topic My first mono-shock
Thanks Mark. I will do that when I remove the swing arm to clean and grease the pivots. Which I plan to do when I buy new tires and tubes. Yamaha no longer sells that bump stopper and I don’t see one on eBay either. So the search begins!
STOPPER, BUMP
2A6-22493-00-00
EDIT:
found it at CMSNL
Last edit: 16 Nov 2026 07:12 by Schu.
16 Nov 2026 07:06 #11
Replied by MarkT on topic My first mono-shock
Here's the thread on rebuilding the shock I just found in the "archives".  First step shows how to get to the bump stop.  yamaha-enduros.com/index.php/forums/how-...oshock-rebuild#76716
16 Nov 2026 09:44 #12
There is a lot of info there and some info on the bump stops I've used near the end
16 Nov 2026 10:07 #13
Replied by RT325 on topic My first mono-shock
If the damping feels constant, not all pogo & uncontrolled, i'd just leave it alone. Bump stop of some sort being external is the easy job. By memory you're dealing with about 14 bar or about 200 psi of pressure or more until a hole is drilled in the base to let it escape [that's the easy job]. If it feels pogo then the pressure will have got past into the oil so a whole new ball game. With the spring off try to compress the shock on the floor etc & you'll be surprised how hard it is to push down if its working as normal. We were one of many service agents for yamaha monoshocks back then [in nz], just standard rebuilds not much modifying in the early days. Anyway--just my thoughts!!.
16 Nov 2026 18:03 #14
