1980 DT175 Piston Clearance
- ESACCO
1980 DT175 Piston Clearance was created by ESACCO
Hi team! Looking for the piston clearance for the 1980 DT175 US
Thanks so much!! I see the later 92 and on non us bike is .040-.045 MM
12 Feb 2025 13:49
Replied by MarkT on topic 1980 DT175 Piston Clearance
Factory Manuals are in tech library here... but yes, same spec as what you posted.
12 Feb 2025 17:34
- ESACCO
Replied by ESACCO on topic 1980 DT175 Piston Clearance
Thank you Mark!!!
18 Feb 2025 16:50
- Paul@PJME
Replied by Paul@PJME on topic 1980 DT175 Piston Clearance
Factory clearances are for factory pistons, this will be very different if using a Wiseco/ Wossner piston.
The following user(s) Liked this Post: Swoop56, Badrul
20 Feb 2025 09:50
Replied by RT325 on topic 1980 DT175 Piston Clearance
Aftermarket kits should have a spec sheet giving clearance--i hope. I'm not up on Wosner but older Wisecos need extra clearance. Mind you i'm not up on modern Wiseco either if there's a difference.
20 Feb 2025 15:07
