1977 DT400 reeds
  • 1977-Dt400
  • 1977-Dt400's Avatar Topic Author
1977 DT400 reeds was created by 1977-Dt400
Does anyone know what VForce reed block fit the dt400? Also any first hand experience with them?
25 Aug 2024 17:29 #1
Replied by RT325 on topic 1977 DT400 reeds
someone on here just put up a video of his RT3 running with a Vforce reed block. Bigger block on the 400 though. I'll see if i can link the page.
yamaha-enduros.com/index.php/forums/1972...rce-reed-block-dt360
Scroll through that to the video although not your model.
Seems like a great idea those.
Last edit: 25 Aug 2024 21:16 by RT325.
25 Aug 2024 21:14 #2
Replied by OldBlue77 on topic 1977 DT400 reeds
I fit VForce reeds to my 77 DT250.
I was recommended by MT to use part number V301C for my 77 DT250. You'll see there is also a version of this sold as part number V4R01H that has full length reed stops.
I used part number V4R01H with no modifications needed to my DT250 when I rebuilt it. So far it has run with no issues, but the bike wasn't running when I first got it. I have no idea what it first ran like before I tore it down to rebuild. I also have a VAPE system installed.
Hope this helps, I'm pretty sure the reed blocks were the same for this year on the 250/400.
Last edit: 26 Aug 2024 18:29 by OldBlue77.
26 Aug 2024 18:24 #3
Replied by 45chop on topic 1977 DT400 reeds
V401H is the same part number I used on my rt3, I did have to grind out quite a lot of metal to get it to fit.
youtube.com/shorts/QCZhw2LQZTQ?si=Opgyk1Kn8AgeQHJN
27 Aug 2024 08:29 #4
