DT175mx 1978 - fitting needle etc
- MikeK-uk
DT175mx 1978 - fitting needle etc was created by MikeK-uk
Hello again,Continuing to reassemble the bike after engine rebuild and having trouble putting the carb back together.I will try to describe as pictures won’t upload at the moment.As the carb came apart…There is the slide,The throttle cable locates into a hole in the slide.A small metal plate is then placed on top and rotated to lock the throttle cable in place.The needle drops through a hole in the plate and rests on the needle clip.All this goes together whilst fiddling with the spring.That’s all there was when the carb came apart.The needle is located by its clip and weight. So the needle can very easily be pushed up from the bottom of the slide. It just sits loosely in place. Is that correct? I have looked at lots of part’s diagrams and none have a plate like mine.Also the slide is very slow to drop or sticks. Should the slide be lubricated? It doesn’t seem right and not sure why.Many thanks in advance for any advice.Mike
13 Jan 2024 09:18
Replied by Gr8uncleal on topic DT175mx 1978 - fitting needle etc
On my RD carbs the plate sits on top of the needle - there will be a hole in the centre of the plate to facilitate this. The big spring on top, then the screw on cap holds everything in place.
The following user(s) Liked this Post: MarkT, Steve F, Swoop56, Ht1kid
13 Jan 2024 09:35
- Pete-RT1
Replied by Pete-RT1 on topic DT175mx 1978 - fitting needle etc
Can be tricky, needle with circlip on drops into slide.
Put the spring over the cable end and compress it into the cap and hold on to it.
Feed the cable nipple through the slotted hole in the slide and slide the cable so that it sits at the other end of the slotted hole.
Now fit the cable stopper plate and let the spring hold everything in place.
The slide should be free moving within the carb when assembled.
Yamaha CT3 (in bits)
In the past, I have used a couple of small crocodile clips to hold the compressed spring into the underside of the carb lid, that way it is out of the way.
13 Jan 2024 10:28
- Schu
Replied by Schu on topic DT175mx 1978 - fitting needle etc
Let me know if you run out of cuss words. Because I just got done installing my carb on a DT175C and I used the whole library until I gave up and removed the airbox to simultaneously install them both. I sounded like Chevy Chase in Christmas Vacation when he went on that infamous rant about his boss!
- automan
Replied by automan on topic DT175mx 1978 - fitting needle etc
The needle is located by its clip and weight. ???
No, by clip to needle, and clip to plate.
There is some needle movement when loaded properly.(.005" or so)
cliff
cliff
13 Jan 2024 11:35
- MikeK-uk
Replied by MikeK-uk on topic DT175mx 1978 - fitting needle etc
I got it wrong (no surprise!). Fitted the needle, then the plate and much more stable now. And it’s the same as a mikuni diagram i eventually found.
What a berk!
Thank you!
Mike
What a berk!
Thank you!
Mike
The following user(s) Liked this Post: MarkT, Snglsmkr, Gr8uncleal, Ht1kid
13 Jan 2024 11:41
No problem Mike.
Everything's easy when you know the answer and there's no such thing as a stupid question - if you don't ask, you don't find out.
13 Jan 2024 11:54
Replied by RT325 on topic DT175mx 1978 - fitting needle etc
Good you're onto it now.
Just be careful the needle actually finds its way into the needle jet as they don't always drop straight in.
Just feel the slide is free to settle right down.
Slide has a side guide pin to--to locate it in the right orientation for the cutaway.
So things to consider--Needle in jet--slide on guide pin--they don't make it easy do they, & those two things pretty much happen together.
Maybe slide goes in a fraction before the needle finds the jet.
You'll now immediately if needle misses the jet as slide will stop going in.
13 Jan 2024 14:46
- MikeK-uk
I’m happy with it now… it all looks right and is operating correctly.
Thanks again.
Right…. See next post on the oil pump!
Mike
Thanks again.
Mike
14 Jan 2024 12:41
