How do I read the carb specs in manual
- bdroie
How do I read the carb specs in manual was created by bdroie
See pic related
I know how to measure it I understand that much
but I have no clue what the symbol or the numbers mean. Do tell.
29 Apr 2023 19:16
- SKYDANCER46
Replied by SKYDANCER46 on topic How do I read the carb specs in manual
Float height adjustment is 26.0mm plus or minus 1.0mm either way is ok. The other numbers are measurements in inches if you choose to use that measurement.
The picture is not related to the float but is showing you the needle adjustment position when you adjust it if needed.
The following user(s) Liked this Post: bdroie
- bdroie
Replied by bdroie on topic How do I read the carb specs in manual
Yeah I thought I cropped it to just show float adjustment
thank you!
thank you!
29 Apr 2023 19:36
Replied by MarkT on topic How do I read the carb specs in manual
Float arms should be pretty much parallel to float bowl gasket surface. In fact, I usually just set them parallel to gasket surface.
(Sometimes Yamaha specs are wrong... and in early years they measured from a different place... so if arms are not pretty close to parallel with gasket surface just as valve closes, something isn't right)
The following user(s) Liked this Post: Ht1kid, bdroie
29 Apr 2023 21:09
