DT175H has spark, compression and plug is wet but wont fire
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Hi Tom, thank you for the reply.  The thought did cross my mind that it was flooded, maybe I'll put things back together and give her another go and kick the crap out of it
As for timing, the DT175H has cdi not points.  I kinda wish it did have points since I've gotten used to timing my DT2 with points and now that seems easy to me.  I just don't get how you could time this system with the CDI, the woodruf key is good and the stator has no adjustment to it...
08 Nov 2022 13:18 #11
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Pete, not saying the exhaust isn't blocked but it did run a few months ago.  I did look at the seal behind stator, it is bone dry so I'm guessing it's not leaking.  As for fresh fuel, sad to say it is not, I can drain the tank and put fresh fuel in it, just got some non alcohol fuel today since good ole Nicole is bearing down on us and wanted to be prepared if I lose power and have to run my generator.  I'll see if I can try that tomorrow, thanks for the suggestions!
08 Nov 2022 13:23 #12
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Lizeec, wish I had someone to push me sadly that's not the case, or at least no one I could ask to do so...
08 Nov 2022 13:25 #13
I've started my 100 & 125 using a reverse drill & a socket. So long as the nut is tight--which it should be--& not a hammer drill Might need to start it with a closed throttle to get it spinning then slowly open the throttle as more air=more compression pressure to turn, i think. Might need two hands on the drill with someone operating the throttle.
Found my video if the link's still live.
The following user(s) Liked this Post: AirborneSilva, Ht1kid, Sneezles61
08 Nov 2022 19:40 #14
Probably due to emissions law, timing is fixed on that model. No adjustment. But makes it easy because there is literally nothing to do but assemble.
08 Nov 2022 21:19 #15
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks RT325 I'll give that a try. Mark, good to know I'll put that back together and quit stressing about it, Thank you to both of you!
09 Nov 2022 02:41 #16
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Well hell! I kicked and kicked and kicked - NO GO maybe this thing doesn't have as much compression as I think it has, that's the only thing I can think. The spark is a nice bright blue spark and I know it's getting fuel, even when I spray brake clean in the carb intake it still wont even pop.
09 Nov 2022 12:27 #17
Choke off when you were kicking?
09 Nov 2022 12:50 #18
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Hi Tom, yes choke off...
09 Nov 2022 12:55 #19
  • AirborneSilva
  • Platinum Member
  • Platinum Member
I think tomorrow, depending on how bad the storm is in my area, I'll go to Lowes and get an adapter for my cordless drill so I can put a 1/2 19mm socket on it to spin the flywheel like RT325 mentioned, maybe I can get it to fire then...
09 Nov 2022 15:10 #20
