78 DT175 Dies
Replied by MarkT on topic 78 DT175 Dies
You'd have to kick it over a whole lot to see oil... no "primer wheel" on that model.
05 Sep 2022 21:39
#11
- 185EZ
Replied by 185EZ on topic 78 DT175 Dies
They're fairly dependable
Pull the oil line at the pump and make sure oil is flowing to it
Check cable and see if it's operating pump
If you didn't have any issues prior then I'm thinking something like the cable or oil supply to pump
06 Sep 2022 17:59
#12
- gwindsor
Replied by gwindsor on topic 78 DT175 Dies
Thank you. I’ll check it this weekend.
07 Sep 2022 17:11
#13
Replied by RT325 on topic 78 DT175 Dies
If it runs just premix some fuel then run it up with line of at the cylinder. Block off the cylinder hole or she'll idle way up dues to extra air in the hole. Then you can pull the cable where it goes into the pump housing & watch the delivery stroke alter from barely visible to quite a long stroke movement & also see the difference in what comes out the line up to the cylinder. Just don't hold that line down hill. Either straight up but messy--or just above horizontal & let it pump drip into a glass but so it has to pump slightly uphill. Could blead the pump out of the little screw in the pump side & just let flow for a minute. Can't see you'd ever get all the air out as screw isn't at the top but is what its meant to be--i guess so the plunger inside is well covered. Guessing a little.
07 Sep 2022 18:06
#14
- 185EZ
Any luck?
Hate it when people ask for help and never return
- AirborneSilva
Replied by AirborneSilva on topic 78 DT175 Dies
Exactly 185EZ, would be nice to know the outcome as someone else may have the same issue so knowing the outcome would help them out!
The following user(s) Liked this Post: 185EZ
02 Oct 2022 15:53
#16
- gwindsor
Sorry for no replies. Checked the oil pump- seems ok. Then put her away for the winter. Just fired her back up today, no fluids new fuel and rode for 20 mins no issue. Have to take a longer ride after the snow melts a little longer. Thanks for the suggestions.
25 Feb 2023 11:10
#17
