Cable Routing Diagram
Replied by Sneezles61 on topic Cable Routing Diagram
After about 5 different ways to ask what I am looking for…. I’ve found this… whew! Thank you for the picts Gr8Al
Sneezles61
06 Aug 2022 08:44 #11
Replied by AirborneSilva on topic Cable Routing Diagram
After looking at Alan's photo's it would appear I have my clutch cable routed wrong on my DT2, thanks for the pictures!
06 Aug 2022 10:01 #12
Replied by swm on topic Cable Routing Diagram
A couple of my original patina bikes the clutch cables are routed thru brace below coil & behind rectifier.  Of course I have no way to confirm they weren't altered over the years but this route keeps cable off cylinder head.  Photo of DT1-S with tank removed.
06 Aug 2022 10:58 #13
That makes sense too… Mine was up above the tank bumpers on the left side so when you turned left.. it put a big strain on the cable… resulting in the kink.. Perhaps having a strong grip, I wasn’t aware it was pulling hard..
The electric loom was hanging below the bumper….
I eagerly await the new cable beginning of this week..
Sneezles61
06 Aug 2022 14:34 #14
Replied by asco on topic Cable Routing Diagram
2022. Bump.
Very Helpful.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
18 Oct 2022 19:49 #15
Replied by SKYDANCER46 on topic Cable Routing Diagram
Here some pictures of the original 71 DT1 i recently purchase. The original 70 DT1 I also recently purchase is routed the same way.  I would guess these are correct. In the past I pretty much have routed all cables this same way on 73 and older DT's and RT's. There all pretty much the same.
If you don't have room to run the clutch and tach thru the frame because of the wire harness on the RT3 then just let them run straight down on the right side like the throttle cable. I think i have done that on some restorations. In fact most all Yamaha enduros including newer models thru 76 and smaller 125/175's route cables on the right side and above the tank mount.
Couple things for sure is all cables run thru the space between the speedo and tach. All wires too. Then throttle, clutch and tach cables run down on the right side of the steering head. The clutch and tach run thru the opening in the frame as shown.
When installing tank make sure round rubber front stay goes over and down past cables and cables stay up on top of the front frame tank mount. this will insure free play and movement for cables once tank is installed. No tie downs or tape on cables either. they will stay in place once tank is on.
After tank is on you should be able to move cables freely back and forth with no snags.
I put the metal band tie on the wire harnesses to hold them in place.  That is not there originally from Yamaha. I like this style because you can make it loose or tight as you want so the wire harnesses will move when steering the bike.
The following user(s) Liked this Post: Swoop56, Yamdog
Last edit: 19 Oct 2022 20:32 by SKYDANCER46.
19 Oct 2022 09:44 #16
I really like that organized routing… perhaps just me, when I see wires all awry, with no rhyme or reason, it causes me to proceed organizing… well, as with many things in life in general too….
Sneezles61
The following user(s) Liked this Post: SKYDANCER46
19 Oct 2022 11:09 #17
Replied by Dennis D on topic Cable Routing Diagram
Was there tape originally where you put the clamp?  The 73 I am working on has a tape wrap in that location and I didn't know if it was factory or a DPO add on.
19 Oct 2022 15:31 #18
Yes there was. There is also a foam piece that goes further down the frame tube, protects the gas tank and keeps it snug at the rear.
Last edit: 19 Oct 2022 20:31 by SKYDANCER46.
19 Oct 2022 16:04 #19
