at3 top end rebuild
  • Nsnnif97
  • Nsnnif97's Avatar Topic Author
at3 top end rebuild was created by Nsnnif97
been fighting getting my at3 running well. found compression isn't great. I haven't tore into it yet to look but  looking into insite for best route. do I go .25 over or stick with standard. or tear down and see how things look then decide if its worth having the cylinder bored
27 Dec 2025 08:05 #1
  • pabdt
  • pabdt's Avatar
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic at3 top end rebuild
Hard to assess based on info given. Any videos? You tube link?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
27 Dec 2025 15:56 #2
Replied by nhsteve on topic at3 top end rebuild
You really need to remove the cylinder and look at the bore before you decide what piston size to go with. You don't know what condition the bore is in yet, could be some gouges from seizures, or just really worn at the top.
Last year I was working on a CT2 top end that did not appear to have seizure issues, but I could feel at the top of the bore how worn that area really was. I think the machine shop had to go 3 oversizes (
) to get a clean bore. Point is, in order to really assess the condition, it needs to be measured and checked before buying parts.
It's tempting to jump in and start ordering bits before you really know what you need. Better to get a good look first, unless you don't mind having bits you won't use. Just sayin'.
You can have that top end off within 30 minutes, no problem!
The following user(s) Liked this Post: MarkT, Nsnnif97, Reed valve Richards
02 Jan 2026 08:57 #3
  • Nsnnif97
Replied by Nsnnif97 on topic at3 top end rebuild
Thanks for the insight! I'll get that off this weekend.
02 Jan 2026 09:11 #4
Replied by RT325 on topic at3 top end rebuild
If your complaint is lack of performance then i'd look at the exhaust providing you have reasonable compression to feel on the kickstart.
Also providing you have points gap around 14 thou to get timing in the ball park.
02 Jan 2026 17:29 #5
RT is quite right about making sure timing is correct, etc. Worth double checking the timing/points gap certainly before whipping the head off (and that alone may tell you quite a bit- With the head removed, rotate the piston down so you can feel and see the top portion of the bore. If you can feel a wear 'step' at the top you need to continue).
03 Jan 2026 08:37 #6
  • Nsnnif97
Update: removed the cylinder my case to cylinder gasket had been leaking for what appears to be some time. cylinder and piston look awesome. Gonna get a set of standard rings lightly hone the cylinder new wrist pin bearings and a couple gaskets. See if I can get this beaut can't be ripping again. thanks for the advise
04 Jan 2026 13:09 #7
That certainly could be the culprit!!
05 Jan 2026 14:33 #8
