rx100 complete stator, cdi , rectifier, coil install on 1974 dt100 points system
- garyramir
rx100 complete stator, cdi , rectifier, coil install on 1974 dt100 points system was created by garyramir
anyone out there know if i can install an rx100 cdi ignition system on a points based 1974 dt100 system to convert it over? Main reason is because im unable to time the points system. its unclear in the manual on how to time.
01 Dec 2025 12:13
- pabdt
Replied by pabdt on topic rx100 complete stator, cdi , rectifier, coil install on 1974 dt100 points system
Not sure but is that a fixed non adj plate on dt 100? You can also use gap to an extent of gap range to set timing.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
01 Dec 2025 20:29
- garyramir
Replied by garyramir on topic rx100 complete stator, cdi , rectifier, coil install on 1974 dt100 points system
thanks for responding. Yes its a fixed plate non adjustable. The only thing adjustable is the mini plate where the gap is, can use a flat head. i should of left it as it was but i replaced the points and condenser and now it dont run or start. i cant follow the timing steps because its unclear in the book drives me nuts. i seen videos of people using little light bulbs to show when the gap opens or closes and also feeler gauge, i just can get the btdc location and mark. i get tdc easily but dont know where to go from there. its too sensitive and difficult to get it exactly timed for me. if i cant time it , im now looking at replacing the entire system to cdi but am on a budget. i seen couple of cdi systems for under $180 but not sure if it work like intended or if i need to change the actual magnet too. i have made several stators for suzuki long ago but that was before pickups, i just did the windings and epoxies/install. what are your thoughts? i also found a complete package off of some tao or lifan enduro cdi system that all the parts look like they fit but have not tried it. it sparks right now. just cant get it to do it at the right time.
just noticed i maybe should of posted this under the 74-75 twin shock bikes instead of the 72-73 twin shock bikes
Last edit: 02 Dec 2025 08:07 by garyramir. Reason: just noticed i maybe should of posted this under the 74-75 twin shock bikes instead of the 72-73 twin shock bikes
02 Dec 2025 07:59
- pabdt
** suggest you check where the condenser wire is connected before moving forward.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
02 Dec 2025 21:10
- garyramir
i got'r running.
The following user(s) Liked this Post: Sneezles61, pahiker
14 Dec 2025 18:01
Replied by MarkT on topic rx100 complete stator, cdi , rectifier, coil install on 1974 dt100 points system
Congrats!
14 Dec 2025 19:14
